Results 1 to 7 of 7
    New ROGer Array
    Sep 2016
    2
    AURA Compatibility without rgb headers [Z170 PRO GAMING AURA]
    Hello,
    There is a bunch of aura's motherboards which unfortunately don't own those "rgb headers" that allow to control your rgb led's color directly from their software.
    If you don't see which are these headers, here they are (picture taken from this website, it is a maximus VIII Hero Alpha):
    Well, I just bought one of them (The new Z170 PRO GAMING AURA) which don't have an rgb header. What an annoying thing when I especially bought it in order to avoid purchasing a led controler. (Yes I forgot to check it, my bad :sarcastic: )
    But well, now that it's done I need to find a solution.. or at least try to.
    So my question is: Is it possible to control RGB LED strips from Asus AURA's software with an AURA motherboard which don't have rgb headers? Is there any trick or any way to connect led strips to my motherboard to successfully solve my problem?
    Thank you
    New ROGer Array
    Sep 2016
    2
    Up!
    ROG Junior Member Array Silvered87 PC Specs
    Silvered87 PC Specs
    Laptop (Model)Lenovo 720s
    MotherboardZ170 PRO GAMING/AURA
    ProcessorIntel i5 6600k
    Memory (part number)F4-3000C15D-16GTZB
    Graphics Card #1ROG STRIX-GTX1080-8G-GAMING
    MonitorBenq G2420HDB / LG49UB820V
    Storage #1ADATA XS8200NP
    Storage #2ADATA SU800
    CPU Coolerbe quiet! Pure Rock
    CasePhanteks EVOLV ATX TG
    Power SupplyThermalTake smart se modular 630W
    Keyboard Logitech G PRO
    Mouse Logitech G900 Chaos Spectrum
    Headset Asus Cerberus Gaming Headset
    Mouse Pad Steelseries DEX
    Headset/Speakers ASUS Cerberus/Genius SP-HF500A
    OS Windows 10 PRO
    Dec 2016
    3
    Unhappy
    I did the same mistake as You. It would be nice if there was some PCIe / USB solution to this problem. Unfortunately there is none. Guess I will go with NZXT HUE+. Expensive but no other way around it
    ROG Enthusiast Array AbyXzss PC Specs
    AbyXzss PC Specs
    MotherboardZ170 PRO GAMING AURA
    ProcessorIntel i7 6700
    Memory (part number)Kingston HyperX 2400 mhz
    Graphics Card #1GTX Asus Strix 1070
    Sound CardSupremeFX
    MonitorSony 32 LED
    Storage #1Kingston HyperX SSD 240GB
    Storage #2Seagate HDD 6GB/s 1TB
    CaseNZXT Razer H440
    Power SupplyAntec 620W HCG
    Keyboard Thermaltake Gaming Series
    Mouse Alcatroz
    OS Windows 10 Home x64
    Nov 2016
    33
    Up! Same issue. I am also doubtful how aura sync works with an ROG certified RAM which supports Aura Synch Geil EVO X, which works if you connect the RAM RGB ports on one of the 4 pin RGB headers on the MoBo but z170 pro gaming /aura does not have one. However Geil Evo X has a 9/12v connector which you can plug on one of the mother board fan/s connector to lit up. Please note the the Geil Evo X does not light up by simply inserting it on the RAM slots it needs to be either plugged on an RGB header or a fan port to supply power on the RAM LEDS. Now the main question here is that if the aura sync software works the same way how the Mobo Syncs with my GTX 1070 strix. If Geil EVO X is powered by the fan headers it still lits up but on a linear phase R/G/B or RGB using the led switch so I am thinking that Aura syncs work only if plugged with an RGB header. So It's quite misleading where Geil EVO X is advertised as Aura sync but does not sync at all on z170 pro gaming aura which is an Aura Sync Mobo. I am hesitant to buy one of the Geil EVO X rams now since I am presuming the aura sync does not work with the RAM and z170 pro gaming Aura
    Bahz, If you can take a look and validate this back end. That will be much appreciated.
    New ROGer Array
    Dec 2016
    1
    Oh mate, same thing happened to me. Just bought this recently and was very excited until I learned that they don't have any RGB headers..
    ROG Enthusiast Array warbosschoppa PC Specs
    MotherboardASUS Z170 Aura/Pro-Gaming
    ProcessorIntel 6700K
    Memory (part number)Model F4-3000C15D-16GVR
    Graphics Card #1ASUS GeForce GTX 1070 STRIX-GTX1070-8G-GAMING
    MonitorBenQ 144Hz
    Storage #1Intel 730 SSD
    CPU CoolerCorsair H115i
    CaseCorsair Carbide Series Air 540
    Power SupplyCorsair RMi850
    Keyboard Custom WASD Keyboard
    Mouse Steelseries Rival
    Headset Thermaltake Chronos
    Mouse Pad Steelseries QCK+ Navi edition
    OS Windows 10 64 Pro
    Nov 2016
    33
    Has anyone else found a way to get this support using a say USB header to AURA adapter or something?
  7. #7
    New ROGer Array
    May 2017
    Quote Originally Posted by warbosschoppa View Post
    Now RGB header there is even on ASUS ROG Strix B250I or ASUS STRIX B250F GAMING, which are significantly cheaper -_-
    I am disappointed
Tags for this Thread
