Results 1 to 2 of 2
    ROG Member Array
    Mar 2015
    6
    G750JX Apparently dead battery
    Hey there folks!
    Thread topic says it all. Some of my work involves field testing, and i take my trusty g750jx with me to desert trips and it copes well.
    I fear, this time i've taunted my luck for the last time, for apparently, the battery is dead..
    However - hwinfo says it suffered only 17% tear. Ive tried uninstalling the drivers for the battery like people here like to suggest.
    I've disassembled the laptop to look for electronical failures but, alas i found nothing.
    Frankly, i've run benchmarks to see if there are any other issues and it's still in the top 33% of userbenchmark's records for this model.
    What other method would i use to be certain that the battery is 100% dead? its 0% and "recharging" but from time to time it seems unplugged.
    Symptoms include mostly orange battery light indicator and it sometimes turns yellow, if only for a second. Pattern repeats.
    Thy help would be greatly appreciated
    ROG Enthusiast Array
    Dec 2015
    38
    Sorry, but I'm pretty sure there's no recovery. Happened to me, and after some research I concluded that I would have to buy a new one. Costed me 80$~.
    I think the reason for why it happened to me was because I had it plugged in for weeks, then suddenly one day I drained the battery to 0%. Thats when It died... xD
