Results 1 to 1 of 1
Thread: FrontBase Fan Control
09-18-2016 07:36 PM #1
Code_Frenzy PC Specs Motherboard Maximus VIII Hero Alpha Processor i7-6700k Memory (part number) LPX 3000MHz DDR4 (CMK16GX4M2B3000C15) Graphics Card #1 Zotac GTX 980ti AMP! Storage #1 (OS) Samsung SM951 256GB NVMe Storage #2 (Data) SanDisk Ultra II 960GB SSD CPU Cooler XSPC Raystorm Pro with custom loop Case Phanteks Enthoo Luxe Power Supply Corsair 1200W (Hx1200i) OS Windows 10 Pro Accessory #1 XSPC Daul bay pump/res, EX420 + RX240 rads Accessory #2 ROG Front Base
- Join Date
- Feb 2016
- Reputation
- 12
- Posts
- 152
I guess I'm one of the lucky ones in that I actually have a semi-working FrontBase!
The CPU temp displays a temperature (not always the exact temperature), the CPU frequency is usually about right (but this too displays what it feels like when overclocking the CPU), and I can't use the front mic port because of background interference.
But at least I can control my fan speeds!
However if wanting to revert back to the Auto control of fan speeds as set by the BIOS settings, how do I select this?
My PC was auto controlling the fans and the FrontBase was displaying the speeds. But now that I have chosen to manually select a speed there appears to be no way to get back to the Auto speed control? I've tried setting it to zero on the FrontBase but this just stops the fan completely. I'm really disappointed with this unit, its all looks and very little function!
Come on ASUS, surely you can do better than this!Last edited by Code_Frenzy; 09-18-2016 at 07:39 PM.
