Results 1 to 6 of 6
    ROG Member Array
    Jul 2016
    5
    Asus Fan Extension Card?
    Where can I buy one?
    ROG Member Array IxRoyalxI PC Specs
    IxRoyalxI PC Specs
    MotherboardAsus Crosshair V Formula
    Memory (part number)CMP16GX3M2X1866C9
    Graphics Card #1Gigabyte Gtx 970 G1
    Sound CardCreative Sound Blaster Z
    Power SupplyCorsair Hx850
    OS Windows 7 Ultimate 64 bit
    Sep 2011
    19
    Quote Originally Posted by %Bart% View Post
    I am looking for this as well. It seems Newegg has been out of stock and that is the only reference of it I can find anywhere.
    Does anyone have any input where this can be purchased at?
    Thanks!
    Asus Crosshair V
    Corsair 16gb 1866 CMP16GX3M2X1866C9
    Gigabyte Gtx 970 G1
    Corsair Hx850
    Corsair H50 CPU AIO Cooler
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    Asus Fan Extension Card, is seems not for selling separately, try to get order from service center
    New ROGer Array
    Dec 2016
    1
    fan extension card
    I was about to buy mine from micro center about 2 weeks ago after newegg had them for a day. even though it says that you'll only get 1 temperature sensor it comes with 3, mounting brackets & screws.
    If you intend to use corsair fans with it you might have a problem. I have sp120's and in ai suite it doesn't detect them when connected to the card (no rpm detected, no speed control) they work fine connected to the MB headers. others have stated the af series is the same.
    ROG Guru: Green Belt Array Detleg PC Specs
    Detleg PC Specs
    Laptop (Model)ROG G750JM, ROG GL 702VMk
    MotherboardRIVE / M8E, EVGA x299 Dark, Maximus XI E
    Processori7-4930k , i7-6700k, i9-7900x, i9-9900k
    Memory (part number)F4-3200C16Q-32GTZR, CMD6GX3M4A2400C9 / F3-17000CL11Q / F3-12800CL7T-6GBPI / PV432G300C6QKPE000378
    Graphics Card #1ASUS GeForce GTX 1080 8GB ROG STRIX / EVGA GTX 780 Hydrocopper, EVGA GTX 1080ti
    Graphics Card #2ASUS GeForce GTX 1080 8GB ROG STRIX / EVGA GTX 780 Hydrocopper/ EVGA GTX 1080ti
    Graphics Card #3EVGA GTX 780 Hydrocopper
    Graphics Card #4EVGA GTX Titan Hydrocopper
    Sound CardCreative Sound Blaster Z PCIe 116dB SNR Gaming
    Monitor3x Samsung syncmaster S24B150, LG4k
    Storage #1Samsung 950 PRO Series - 256GB PCIe NVMe - M.2 Internal SSD
    Storage #21x 500gb Samsung SSD 850 EVO,1x 256gb Samsung 840 Pro, 1x WD 10k mech
    CPU CoolerKoolance CPU-380I , 2x custom water cooled loop EKWB
    CasePhobya WaCoolT Test Bench, TT Tower 900
    Power SupplyEVGA SuperNOVA 1300 G2, 80+ GOLD 1300W, ROG THOR 1200 Platinum
    Keyboard Logitech K800
    Mouse M705
    Headset Logitech G930
    Mouse Pad EVGA PWNAGE
    Headset/Speakers Audio Engine S8 / D1
    OS Win10x64, Win 8.1, Win 7 Ulti x64
    Network RouterUbee
    Accessory #1 2x 360 big ass radiators push/pull corsair fans
    Accessory #2 OC Panel II
    Accessory #3 A couple of great Noctua pwm fans
    Detleg's Avatar
    May 2013
    33
    656
    I got an extra one, sell it to you for 1 Million Dollars......just kidding ebay got plenty just like they do the OC panel I and II
    ROG Guru: Yellow Belt Array
    Mar 2016
    8
    208
    Quote Originally Posted by PennIsMightier View Post
    Not true. I have 2 140 mm corsair blue led ML connected to the fan extensions card and they work just great in Aisuite III. I can control the fans just fine.
    Check if your fan extension connector to the Motherboard is ok. and the molex 4 pin is connected to the fan extension card.
