ASUS Z170 PRO GAMING memory module+post issue...
OregonMike
I'm unable to get my system to POST, in bare bones mode, when installing all four memory modules.
I've confirmed that all four modules work fine as do the slots on the mobo.
It's only when all four are installed when the issue repros.
Components being used:
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz
COOLER MASTER RR-212X-20PM-R1 120mm
CORSAIR Vengeance LPX 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Memory Kit Model
CORSAIR HXi Series HX1000i
When only installing three memory modules along w/ my SSD+HDD+Blu-ray drives and EVGA GeForce GTX 950 gpu,
the system works fine so I don't believe it's a power issue but am not certain.
Nate152
Hi OregonMike
With one stick of ram installed try setting the Dram voltage to 1.25v - 1.30v then shut down your pc and install the other sticks.
Does this get all four sticks working?
