Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Sep 2016
    8
    insane FPS drop?
    i've bought asus rog GL752VW recently here are my rigs
    core-i7 6700HQ
    ram 16g
    gtx960m 4gvram
    128g ssd +1TB HDD
    17.3inch full HD
    win 10 home 64bit , x64 based processor
    if u need to know anything else please let me know
    when i first booted my laptop and started battlefield 3 FPS on ultra setting was like 45-55 FPS then after a couple of min it came down to about 35-45 today
    it dropped to like 29-35 avg temp is approximately 80C i feel that there is something limiting gpu's performace or is it temperature? but i dont think this temp for
    laptop is too much any help appreciated
    ROG Enthusiast Array gustmi4 PC Specs
    gustmi4 PC Specs
    Laptop (Model)Asus CM 200 Chromebook, HP Chromebook 14 (second gen), Lenovo T400
    MotherboardAsus Z170-A
    ProcessorI5-6600K
    Memory (part number)Kingston HyperX Fury DDR4 2666 MHz 16GB
    Graphics Card #1Gigabyte 980Ti G1 Gaming
    MonitorAsus VE228 21,5"
    Storage #1Corsair Force LE 240GB
    Storage #2Kingston HyperX 120GB, Intel 330 120GB
    CPU CoolerNoctua NH-U12S
    CaseFractal Design R4
    Power SupplyEVGA SuperNOVA 750w G2
    Headset AKG K702, Steelseries, Logitech
    OS Win 10 Pro 64-bit
    Sep 2016
    51
    Seems Asus has set the throttling temp to 75-78C on the GTX960M.
    Here's a long thread about the issue:
    https://rog.asus.com/forum/showthrea...degree-celsius
    -Mikael
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi Mustafaw
    Try cranking the fans up this should lower temps.
    ROG Member Array
    Sep 2016
    8
    Quote Originally Posted by gustmi4 View Post
    -Mikael
    i guess this is the problem but it seems quite old thread is there like updated version of that bios if u have any info on that?
    gustmi4 PC Specs
    ProcessorI5-6600K
    Sep 2016
    51
    Sorry to say I don't have any more info.
    The last post in that thread is from today (page 26) and it seems to be pretty active. You could probably get the best answer by posting on that thread.
    Did only look quickly at the thread and it seems they're modding the vbios themself, so it wouldn't be asus approved and at your own risk.
    Though, as said, they will probably be the best to give you some more information.
    -Mikael
    ROG Member Array
    Sep 2016
    8
    Quote Originally Posted by Nate152 View Post
    Hi Mustafaw
    hi Nate, do u think using a cooler might help?
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    A laptop cooler should help but I don't know how much since I don't use a laptop, you could ask this question in the notebook section of the forum.
    You could try installing gpu tweak II and crank up the gpu fan and see how much temps drop, you may also be able to overclock your gtx 960m for improved performance.
  8. #8
    gustmi4 PC Specs
    ProcessorI5-6600K
    Sep 2016
    51
    you may be able to overclock your gtx 960m for improved performance as well.
    Wouldn't that be pretty counterproductive as it's already throttling?
    -Mikael
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Well, you can't increase the voltage on a laptop gpu but you can increase the clock speeds so it shouldn't affect temps much if at all.
  10. #10
    gustmi4 PC Specs
    ProcessorI5-6600K
    Sep 2016
    51
    True Nate. =)
    So crank up the fans to begin with as Nate152 said and see what happens to the temps.
Tags for this Thread
