Results 1 to 6 of 6
    amitgedia Array amitgedia PC Specs
    amitgedia PC Specs
    Motherboardasus rampage v
    Processori7 5820K
    Memory (part number)Corsair Vengance 4x4GB
    Graphics Card #1Nvidia Quadro 600
    MonitorLG Flatron E2360
    CPU CoolerCorsair H110i
    Casecoolermaster HAF 932
    Power Supplycoolermaster 700W
    Keyboard Microsoft
    Mouse Logitech
    Headset Philips SBH 4000
    Mouse Pad Intel Extreme
    OS Win 7 64 bit
    Network RouterMTNL DM 856W
    Nov 2015
    32
    31
    (Solved) Asus Geforce GTX 1070 Strix problem
    hi guys,
    just got a geforce gtx 1070 strix 08G gaming and installed it on my asus rampage v extreme and turned on the system but the system would not boot.
    there is led lights on the motherboard and the white light on the graphic card but the system would not boot
    i removed it and plugged back my old quadro 600 and bang the system booted and started and everything was fine
    so again i plugged back the new 1070 on the motherboard and it would not boot up
    what is the problem, what should i do...please help... have spend $ 492 to get this new card and waited for 1.5 months to get it and its not working
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,345
    Hi amitgedia
    You may need to uninstall the Nvidia quadro driver then install your ROG Strix 1070, be sure to connect the 8-pin pcie power cable.
    amitgedia PC Specs
    Processori7 5820K
    Keyboard Microsoft
    Mouse Logitech
    OS Win 7 64 bit
    Nov 2015
    32
    31
    I have cooler master v850, so u mean the PCI-E (6+2 pin) to PSU(6 pin) cable right....
    Quote Originally Posted by Nate152 View Post
    Hi amitgedia
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    Yes use the 6+2 pin pcie power cable.
    amitgedia PC Specs
    Processori7 5820K
    Keyboard Microsoft
    Mouse Logitech
    OS Win 7 64 bit
    Nov 2015
    32
    31
    guys voila.... i changed and put the correct cables and it worked... it was my bad... in excitement i put wrong cables and it didnt work, but now everything is fine and running...
    thanks guys once again....
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,345
    You're most welcome !
