Looking for updated M.2 fan holder
nightstrike
There's a fan mount for the M.2 socket here:
http://rog.asus.com/articles/pc-mods/download-3d-printable-parts-now/
Does anyone have an updated design that fits the M8E, ideally in a way that doesn't block the BIOS LEDs or the four pins below the LED?
(Aside: Anyone know what those 4 pins are for?)
nightstrike
Bump? I asked Asus support about those pins, and they don't know what they're for 🙂
Severan
I know I'm late to this game but, I've just printed an m.2 cooler mount, and installed it on my Asus VIII hero without an issue. I'm looking at the Maximus VIII Extreme and I fail to see anything conflicting with the mount, can you take a picture? Regardless, if you have some plastic conflicting, just pull up a dremel and remove it. The cooler mount will be mounted to the standoffs, so you won't notice a difference.
