Results 1 to 2 of 2
    ROG Guru: White Belt Array
    Apr 2014
    84
    Anyway to make rear audio input (pink or light blue) to be headphone out
    I currently have a Z5300 populating the green, black, and orange ports. I then have my Hyper X Cloud II connected to the front audio jacks on my Air 540. What I want to do is connect my Beyerdynamic DT 990 PRO 250OHM headset to either the pink or light blue jacks on the board since they are the only two not populated. I tried the light blue but was prompted with only side speakers out or mic in as a choice. I didn't even bother connecting to Mic as I assumed I would only get mic in as a choice. Is there specific settings to allow those jacks to give other options as output or am I just stuck with swapping my front output all the time between my Cloud II and the 990 Pro's?
    Board is a MVIIIF.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,443
    Hi scgt1
    You're stuck swapping them out, pink is always microphone and green is always speakers.
