Results 1 to 3 of 3
10-16-2016 05:40 PM #1
- Join Date
- Dec 2014
- Reputation
- 10
- Posts
- 8
ROG Front Base CPU FAN & OPT CPU FAN Error
Hello,
I have a Asus Rog Front Base since 1 year.. (It's a version with Sticker V44) The last year I have a lot of problems for intall This Panel.. But Finally it works with all his fuctions (Windows 10).
Yesterday I Spent a lot of Hours install it because I Re-Format my PC and I Install Again Windows 10.
Finally it works with a oldest Drivers.. ( I install the Realtek Audio and AISuite with some issues) But it works.. CPU Shows the Speed, Fans Works and Temperture Works..
But I have a Strange error... If I Up the speed Of CPU 1 The Speed Of CPU 2 up too..
I want different Speeds on the 2 Fans..
The fans are Corsair SP replacement From a Corsair H80i (2700rpm Both) Why if I up CPU 1 the CPU 2 up too?
Actually I have installed this:
Rog Connect Plus 1.00.32
Front Base Driver 1.01.17
Windows 10
Asus Maximus VII Hero..
Bios 3003
The last year the panel works great.. But now With the clean system...
Any Idea???
Thanks a lot..
10-18-2016 06:15 PM #2
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
I have no experience with the ROG Front Base. But what I can tell you is that the CPU_FAN header and the CPU_OPT header are linked together with the CPU_OPT header being the slave. So whatever setting you decide to choose for the CPU_FAN header will automatically reflect on the CPU_OPT header.
10-28-2016 10:52 PM #3
- Join Date
- Dec 2014
- Reputation
- 10
- Posts
- 8
