I’ve used the followings RAMs to conduct and conclude the test outcome.
• CMK16GX4M2B3000C15 (Corsair) (listed in QVL)
• F4-2400C15D-16GVR (G.Skill) (not listed in QVL)
I bought the motherboard back in 20 February 2016 and CMK16GX4M2B3000C15 was used to install the computer. However I encountered an issue with the DIMM slots in the course. According to the motherboard user manual page 1-10, if I have 2 sticks of RAM, the recommended memory configurations should be installed in DIMM_A2 and DIMM_B2 slots. Unfortunately to no avail, the computer would not boot up and it displayed code 55, RAM led was lighted.
After hours of trial and error, I’ve gotten the computer to boot up by using DIMM_B1 and DIMM_B2. Naturally in the course of trying to fix it, I did update the BIOS to the latest version available at that point of time. In a nutshell, this should not be the configuration.
Since I’m able to get the system up and running, I let the issue slipped and assumed maybe I gotten a “problematic” RAM.
Lately I’ve decided that 16 Gb isn’t enough and I wanted to upgrade to 32 Gb. This time instead of buying back the same brand (which I assume isn’t so good as it caused the issue mentioned above), I thought why not buy other brand which is slightly cheaper and have equally good reputation in terms of quality product. So I went ahead and purchased F4-2400C15D-16GVR, 4 sticks of it.
To my horror, I was not able to boot up the system after installing all 4 sticks of G.Skill RAMs into all DIMM slots! At that point, I’m pretty sure I’ve updated to the latest BIOS version 2202 and should have fix any know issues by then. It was frustrating.
I’ve gone through the similar trial and error I did back then, and realized that the system was able to boot up using only 2 sticks of G.Skill RAMs on DIMM_B1 and DIMM_B2. If both RAMs were installed base on the recommended configuration, it won’t boot.
Right now I’m on 16 Gb GSkill RAM (2 sticks) and working fine.
