rog front base installation
deejaykristoff
hello, have some doubt about how to connect front base, it is necessary to connect the sata cable? because i dont connect it and all work flawlessly just with audio and ext cable on a z170 hero, is it normal?
Code_Frenzy
There is no SATA cable on the Front Base, I think you may be referring to the USB 3 header cable?
