Results 1 to 2 of 2
10-24-2016 10:48 PM #1
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 8
Process "System" using 100% CPU0?
Hi, my laptop has got this process "System" with description "NT Kernel & System" taking up one single core (usually CPU0 occasionally CPU2) 100%. It got my attention when I started feeling the keyboard got warmer than usual. I installed all the latest drivers recently, not sure if that could be the cause? If so, how can I check which driver might be bad? I read someone suggested to take a look at my USB driver.
Edit: Even when I boot into Safe Mode, the CPU0 is still full at 100%, with "System" at the top of the list.
10-25-2016 12:49 PM #2
JustinThyme PC Specs Laptop (Model) G752VY-DH72 Motherboard Rampage VI Extreme Processor I9 9940X Memory (part number) 64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17 Graphics Card #1 ASUS Strix 2080Ti O11G @ 2.1GHz Graphics Card #2 ASUS Strix 2080Ti O11G @ 2.1Ghz Graphics Card #3 ROG Nvlink Graphics Card #4 Have to feed animals Sound Card External Audioengine D1 24 bit 192kbps DAC Monitor ASUS PG348Q @ 100Hz Storage #1 Intel 905P 480GB U2 flavor Storage #2 Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1 CPU Cooler HeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS Case Phanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM Power Supply Corsair AX 1500i Keyboard ASUS Claymore Mouse ASUS Spatha, Logitech MX Master Headset Sennheiser HD 700 Mouse Pad ASUS ROG Sheath Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub OS Win10 Pro 1809 Network Router NetGear NightHawk X10 Accessory #1 NetGear Prosafe 10GBe Switch Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,855
Id put my bet on one of the drivers you installed recently.
