FN+NUMLK for max fanspeed - G752
gtan777x
Hi all,
I know everyone already knows the fn+num lock trick to max out fans with the only downside that you can only return to normal speed by shutting down. Just wanted to check if anyone has found key combo for normal speed? Also maybe other key combo that are not obvious but work like
FN+down arrow = play/pause, FN+up arrow stop, FN+left arrow = prev, FN+ right arrow = next. Remembered these from the old G55.
Also Ive got a G752VT - has anyone tried to install the gaming center build 2.0 or 1.12 that is meant for the VS and GX700? Saw that they had controls for fanspeed and wondered if it would work.
Gps3dx
Level 12
look at my sig for "HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"
it might work for G752 serie as it does with the G751.
if you can create some script that changes the fan speed then AsusNBkey can mod existing FN combo to run such script.
Asus G751JT
Samsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
  • [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
  • [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
  • [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
  • [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
  • [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
