G751JT Fan oiling
Vyary
Hello Rogers,
I want to oil my fans but they cant be opened to do so my question is can i make a hole in the fan and to oil it like on this video.
https://www.youtube.com/watch?v=GugKVoSTVFs
Regards
Clintlgm
Level 14
I should think that is your fans need oiling, that it would be best to replace them. adding Oil into the internals of a notebook wouldn't be a good Idea.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
Sanctrum
Oil does not cunduct current. However I agree with Clintlgm... if you need to oil fans you better replace them.
I olied fans using WD40 twice in my life... It was working... but I have never done this for laptop fans.
Compwxr
I've done it a lot of times in old Asus laptop and never had a problem. Solved all the rattling issues without spending money.
- Compwxr - Volter Team - Check us at http://voltground.com
