Results 1 to 7 of 7
    ROG Guru: Yellow Belt Array FonzieBulldog PC Specs
    Laptop (Model)Asus AMD Blue Ghost
    MotherboardAsus ROG Strix X570-F Gaming
    ProcessorAMD Ryzen 7-3800X 3.9 GHz
    Memory (part number)G.Skill Trident Z Neo DDR4 3600 MHz 4x16GB 64GB
    Graphics Card #1Asus GeForce RTX 2080 Super ROG Strix OC
    MonitorAsus 3D 32´
    Storage #12x Samsung M.2 SSD EVO Plus 970 1TB
    Storage #22x Samsung SSD EVO Plus 860 1TB
    CPU CoolerAsus ROG Ryujin 240mm
    CaseMission SG GGX 3.6 Tempered glass
    Power SupplyAsus ROG Strix 750W Gold
    Keyboard Razer
    Mouse Razer
    Headset Razer
    Mouse Pad Razer
    Headset/Speakers Razer
    OS Windows 10 X64 Pro
    FonzieBulldog's Avatar
    Aug 2016
    14
    185
    Noisy water cooler fans.
    Have two computers there one is a updated G20CB with GTX 1080 and i7-6700K who runs with Asus original two small fans in this box.Really quiet for sure.The other one is the home built Bulldog with MSI GTX 1080 Gaming X and a i7-6700K who runs at 4.6Ghz.The water cooler in form of a Corsair Hydro H80i V2 holds everything on a low temp but the fans sounds really tiring even at the silent mode there they go up and down depending on the heat.If i set it in game / heavy mode it sounds like an airport in my living room !?.Is this actually how a water cooler works or is there a way to get it some quieter.
    ROG Member Array We Gone PC Specs
    We Gone PC Specs
    MotherboardASUS Hero Alpha
    ProcessorI7 6700K @ 4.5 @1.312v
    Memory (part number)Corsair 3200 4x8 @ 3300
    Graphics Card #1GTX1070
    MonitorPG279Q & 226BW
    Storage #1Sansung 850 500gb SSD
    Storage #22TB Seagate
    CPU CoolerApogee Drive II
    CaseCM Stryker
    Power SupplyEVGA P2-o750-X1
    Keyboard Logitech G810
    Mouse Logitech G502
    Headset/Speakers Logitech 5.1 X-540
    OS W10
    Aug 2016
    13
    9
    You may need to run a larger radiator so it will cool better with lower air flow. I run a dual 120 and unless I'm stress testing I only run the fans on low or not at all. I7-6700@ 4.5, Idle stays at room temp gaming never over 40c no fans.
    MonitorAsus 3D 32´
    Keyboard Razer
    Mouse Razer
    Headset Razer
    Mouse Pad Razer
    Aug 2016
    14
    185
    Yeah, maybe have to try out a bigger radiator if i get enough tired of the fan noise one day.Thanks for the reply.
    ROG Enthusiast Array 28BeersLater PC Specs
    MotherboardRampage V Extreme
    Processori7-5930K
    Graphics Card #1ROG Strix Vega 64
    Sound CardBose External USB
    MonitorLG IPS235 x3
    Storage #1Kingston HyperX Predator 480GB
    Storage #2Corsair Neutron XT Series 960GB
    CPU CoolerEK RVE Monoblock
    CaseCorsair 900D
    Power SupplyCorsair AX1200
    Keyboard Logitech K800
    Mouse ROG Spatha
    Headset/Speakers Bose Companion 5
    OS Windows 10 Pro
    Network RouterROG Rapture GT-AC5300
    Jun 2016
    71
    I ran a H100i temporarily on my Rig when I was making sure that the new components were all good before fitting the Monoblock and entering an RMA nightmare..
    I found that plugging the PWM fans into the motherboard PWM header, instead of the Corsair one gave much better results. Make sure the fan headers are configured to run in PWM mode, obviously.
    Feb 2015
    11
    155
    Or better still....
    Ditch the AIO water cooler and get a Noctua NH-D15S. Whisper quiet and cools my 6700K at 4.6 GHz with ease. Core temps running RealBench are 75 degrees. and the ambient temp was high the day when tested. I reacll 25C. Very cool in games, so much so the PWM fan hardly needs to ramp up.
    It has only one fan, but a second fan reduces temp by only 2 degrees, same for the NH-D15/14. Clips are provided if you're insistent on a second fan.
    This is the "S" variant, the high compatibility version for much better RAM compatibility and offset slightly for more space between graphics card and cooler.
    And don't let anyone tell you the weight is an issue... it's nonsense. The D15S's dynamic load is lower than Intel's stated max for Skylake. Static load is higher by design, to improve cooling, but not an issue. The SecuFirm 2 mounting system is the best in the business.
    I'm not serious when I tell you to "ditch your AIO cooler" of course, just trying to highlight how there is an alternative to AIO that does everything you desire.
    MonitorAsus 3D 32´
    Keyboard Razer
    Mouse Razer
    Headset Razer
    Mouse Pad Razer
    Aug 2016
    14
    185
    Thanks for the replies.Will try to change the fan connections to the motherboard instead of the Corsair connections.Or i maybe have to try out the Cooler Master again who i have lying around somewhere.
  7. #7
    ROG Guru: Yellow Belt Array Legolas PC Specs
    Legolas PC Specs
    MotherboardMaximus X Hero Wifi AC
    ProcessorIntel Core i7 8600k oc 5Ghz
    Memory (part number)Samsung DDR4 16GB
    Graphics Card #1ASUS NVIDIA GTX 1080
    MonitorASUS MS246
    Storage #1Samsung MZVPV256
    Storage #2Samsung MZVPV256
    CPU CoolerCorsair H110I v2
    Power SupplyPC 1200W Turbo-Cool 1200
    Keyboard ASUS SK2045
    Nov 2015
    242
    Quote Originally Posted by FonzieBulldog View Post
    Hi FonzieBulldog,
    Did you try changing the fan speed in Corsair Link software? If you have it, open, go to Configure, double click on the Corsair FAN image, and change the mode to Balance or Performance (if it was max) and your fan speed will not as noisy. You can even change it to quiet (for silent mode)
