11-12-2016 12:49 PM - last edited on 03-06-2024 01:31 AM by ROGBot
11-12-2016 01:08 PM
AAstroPhysics wrote:
Hello there 🙂
I am new at this forum. I hope we will have fun together. Atleast for my English... Yeah i have very big English problems. Anyway ! 🙂
So the problem is I have a Side fan installed right now. But my GPU temperature is getting worser. I don't know what i am doing wrong, but i can exactly feel that my GPU trying to get the hot air out of the Case. I can barely feel that when i put my hand on the Side panel. By the way i am using my fan as intake. But when i search this problem on the internet, everyone says that it should be an intake fan. I terrified right now. So i beg you for your help.
Thanks 🙂
-Okan
11-12-2016 01:18 PM
KING DRANZER wrote:
AS you are using ASUS STRIX GPU use the fan as exhaust.
11-12-2016 01:25 PM
So, The fan should take the air inside of the case and exhaust outside. Am i right ?
11-12-2016 01:31 PM
KING DRANZER wrote:
Yes fan should push hot air produced by GPU out of the case.
11-12-2016 01:42 PM
11-12-2016 02:44 PM
KING DRANZER wrote:
Okay to be more clear I will explain how it works.
The GPU intakes the air Using fans attached to it and lets the air out from the top. As your GPU is placed in upright position in reference to motherboard which means the fan on the side panel must be placed near to its top. As the fan is near to the top of the GPU the fan when set to push the air out as exhaust cools the GPU in a better manner.
If you could provide the Case model or where exactly the fan is, then I could provide better answer.
11-12-2016 08:03 PM
11-12-2016 09:29 PM
11-13-2016 08:40 AM
KING DRANZER wrote:
Yes use that fan as exhaust and if possible throw a fan at bottom for intake and run your cables from back(cable management).
