Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array
    Oct 2016
    11
    ASUS MAXIMUS VIII EXTREME + Samsung SSD 850 PRO
    Recently I setup my new pc and formatted my computer to windows 10 x64 and connected my SSD to SATA6G_1 and enabled AHCI in bios, updated bios to latest, and installed all Asus driver from the website but in Samsung magician it gives me "AHCI Deactivated", and in windows driver it also give me SATA AHCI
    What i'm missing ?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi hamood_d10
    Welcome to the ROG forum.
    In samsung magician check for a firmware update and see if that fixes things.
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    Quote Originally Posted by hamood_d10 View Post
    What i'm missing ?
    hi hamood_d10
    Did you install Intel IRST drive for SSDs or just use Win10 native default Driver?
    ROG Member Array
    Oct 2016
    11
    Quote Originally Posted by FuryA@ASUS View Post
    hi hamood_d10
    I installed intel IRT or should I uninstall ?
    ROG Member Array
    Oct 2016
    11
    Quote Originally Posted by Nate152 View Post
    Hi hamood_d10
    Everything is updated in my system Bios, Firmware, Drivers, everything
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,788
    Try connecting to a different SATA port and make sure that port is enabled (and recognized) in the bios.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    As NemesisChild says make sure your 850 pro is connected to an intel sata port.
  8. #8
    ROG Member Array
    Oct 2016
    11
    Quote Originally Posted by NemesisChild View Post
    From the manual here (Page 1-38)
    http://dlcdnet.asus.com/pub/ASUS/mb/...EME_UM_WEB.pdf
    Connected the Samsung to B section in SATA6G_1 as I mentioned up (Not Fixed)
    Connected the Samsung to A section in SATA6G_5 or 6 and checked but its the same results (Not Fixed)
    Checked in bios and yes its recognized and AHCI enabled (Not Fixed)
    Uninstalled "Intel Chipset, IRST, MEI" and install them again (Not Fixed)
    BTW I called my friend since he have the same rig as I do but he customize it as he likes and he had the same issue
    It would be great if it someone who can help me here
  9. #9
  10. #10
    ROG Enthusiast Array nikos xatz PC Specs
    nikos xatz PC Specs
    MotherboardMAXIMUS VIII HERO
    ProcessorSKYLAKE i7 6700K
    Memory (part number)32GB CMD32GX4M4A2400C14
    Graphics Card #1ASUS GTX 970 STRIX
    Storage #1SAMSUNG 850 EVO 25O GB
    Storage #2ST500LM000-1EJ162
    CPU CoolerEK-WB CUSTOM LOOP (CPU + GPU)
    CasePHANTEKS PRIMO WHITE
    Power SupplyCORSAIR HXi 750
    Keyboard CORSAIR STRAFE RGB MX SILENT
    Mouse ASUS ROG GLADIUS
    Mouse Pad CORSAIR MM200 EXTENDED EDITION
    OS WINDOWS 10 PRO 64
    Network RouterNETGEAR NIGHTHAWK D7000
    nikos xatz's Avatar
    Nov 2015
    32
    It's a Bug on the Software Samsung magician Since Windows 1607 Update.Not to worry about.....
    Search in Google about it.....
