Results 1 to 4 of 4
    ROG Member Array alexandruww2 PC Specs
    MotherboardASUS B150M K DDR4
    ProcessorI3 6100
    Memory (part number)DDR4 HYPERX BLACK 1X8GB 2133MHZ
    Graphics Card #1GTX 1060 3GB OC ASUS DUAL
    MonitorAOC 18.5"
    Storage #12TB SAMSUNG 5400RPM 32MBCACHE
    CPU CoolerZALMAN CNSP8X
    CaseDEEPCOOL SMARTER
    Power SupplySIRTEC HIGH POWER ELEMENT PLUS 500W
    Keyboard JAF
    Mouse A+ G3 GAMING ODIN
    Headset HAMA KNALLBUNT
    Mouse Pad A4TECH X7
    OS WINDOWS 10 64 BIT HOME
    Network RouterHUAWEI
    Nov 2016
    6
    GPU TWEAK GTX 1060 COOLING ISSUES's need help with USER DEFINED fan settings
    Hello, I run an asus dual 3gb oc gtx 1060 for 3 days, and I need some help
    If i let the gpu tweak at AUTO mode....the fan goes 28% untill gpu hit 70...thats STUPID i don't want my gpu stutter my games on high temps like already happend
    it also VERY LOUD above 50% not acceptable,VERY LOUD, i can hear it even with my overhead headset too!
    can someone give me some good user defined fan settings for gpu tweak to avoid suddently fan speed inscrease and loud sounds increase?
    my actual is untill 40% at 52C 68% at 56C and 100% at 73C
    is this good? it still makes alot of nois when hit above 50% but i don't want to fk up and stress the gpu to reach 56 or 73 untill reach 100% (
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,445
    Hi alexandruww2
    You can set the fan manually to say 40% and see where that puts temps while playing a game, temp in the 70's should be fine as thermal throttling won't happen until the temp hits 80c - 82c, as long as you stay below that you'll have maximum performance.
    You can play with the fan curve to find where you need just enough fan speed to keep temp below 80c this should have it running as quiet as possible while maintaining maximum performance.
    ProcessorI3 6100
    MonitorAOC 18.5"
    Keyboard JAF
    Mouse Pad A4TECH X7
    Nov 2016
    6
    thank you
    i tried GPU TWEAK user define settings
    in bf1 alot of stuttering even at low
    every explosion fk up the game with lag spikes from 90 fps to 30 and 11 and stuck and back to 60 80 the cpu is not the bottleneck stay's at under 70% usage
    i will try as you said
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,445
    I don't have BF1 but I've read that setting the game to directx 11 gives better performance than directx 12, you could try that too.
    Here's a video showing the performance difference with a gtx 1070.
    See the Frames Per Second in green side by side at the top in the middle of the screen.
