11-18-2016 08:13 PM - last edited on 03-06-2024 01:29 AM by ROGBot
11-18-2016 08:25 PM
11-19-2016 04:23 AM
Nate152 wrote:
Hi LordSilver
Welcome to the ROG forum.
Go into the bios and hit F5 to reset to defaults, enable XMP then F10 and enter.
Boot to windows and check to see the windows power plan is set to balanced.
Is your cpu now idling at 800MHz ?
11-19-2016 06:40 AM
11-19-2016 02:55 PM
Chino wrote:
Clear your CMOS and use the Balanced profile without modifying anything. Open CPU-Z and let your system idle a few. Report back your results.
11-19-2016 04:13 PM
11-20-2016 03:40 AM
Nate152 wrote:
You could install real temp 3.70, that will show if something is putting a load on your cpu.
https://www.techpowerup.com/downloads/2089/real-temp-3-70
11-20-2016 05:39 AM
11-20-2016 12:58 PM
JustinThyme wrote:
My bet is its a back ground app that will settle out. If you use the resource hogging Symantec AV you can count on it. Drive indexing hits it for awhile but eventually settles out.
Boot into safe mode and see what you get.
11-20-2016 01:27 PM
