Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Enthusiast Array
    Aug 2015
    67
    Asus G752VS Turbo gear update for Overheat Issue
    Hi.
    Came out two days ago a new update specifically for the "Turbo gear". The name of the update is "Turbo gear update".
    Some of you said that overheat is caused by a bad "voltage" used by turbo gear, and recommended not use him or unistall.
    Someone have try this new update? He fix the overheat and the throttle when overclock? Fix the high voltage?
    In the description of the update says "Turbo Gear Updater is used to update ROG Gaming Center overclocking configuration" , "Notice: System need a reboot to apply the configuration update".
    Please when try or use, leave or feedback here.
    The update can be found in Asus Web-site, in the part of "Utilities".
    Thanks
    ROG Member Array
    Nov 2016
    5
    I would also like to see an update to this, and see how they're fixing the heating issues!
    Nov 2016
    15
    32
    I will try to find it now and try it out
    Nov 2016
    15
    32
    milne transito
    here is the shot of a cpu stress with cpuz seems the volts are lower not sure of any other changes and under stress on exstream it doesn't throttle now. but I will have to test with bf 1.. I have been playing with the settings for days now and found that bf 1 would over heat and throttle when the cpuz stress would not.
    Attachment 60426
    realbench of 111926 on extream max package temp of 90
    v of 1.72 at the highest point and only for a second... most of the time around 1.55
    ROG Guru: Orange Belt Array DeltaActual's Avatar
    Dec 2011
    34
    357
    So what's going on with this update? Did it fix the VS *throttle issues?
    GL704GW
    Aug 2015
    67
    The same doubt here. Still waiting for the feedback of someone ... Did it fix the overheat and high temps?
  7. #7
    Nov 2016
    15
    32
    rundles waldorf
    have not had one throttle or over heat with it on extreme with any of the benchmarks or game that I do, unlike before patch.. now to get this keyboard firmware fixxed
  8. #8
    Dec 2011
    34
    357
    Quote Originally Posted by MDFMac View Post
    That's good to know
    Thanks man*
    GL704GW
  9. #9
    ROG Guru: White Belt Array
    Dec 2013
    95
    Hi there.
    Got some questions about this I hope you can answer.
    Are you still running the Asus gaming center version 1.0.12 with this?
    How did the installation of Turbo Gear Updater go exactly?
    Do you know exactly what the Turbo Gear Updater did?
    Did you run benchmarks for before and after running the Turbo Gear Updater?
    Thanks!
  10. #10
    Nov 2016
    15
    32
    the update makes it so it don't over heat and throttle down as hard as it was doing. if you bench it at standard then extreme you will find its worse on extreme unless you put in the patch because of the throttling
Tags for this Thread
