Results 1 to 4 of 4
    ROG Member Array
    Nov 2016
    21
    Guidance on minimizing GL702VM heat/noise by lowering the CPU/GPU voltage?
    Hi all. I got bored of waiting for the 1050Ti to be released & have just bought a GL702VM that was on sale.
    Any guidance on keeping heat/noise to a minimum? Happy to sacrifice performance.
    I've seen people talking about lowering the CPU/GPU voltage, but not sure whether this can be achieved using Asus's tools, whether it'll be in the bios settings or something else.
    Thanks in advance.
    New ROGer Array
    Nov 2016
    1
    University
    I would also like to know about this, I am considering this to take to uni, and would like to be able to make it extremely quiet for in lectures and such. I planned to just switch to integrated graphics when I needed it to be quiet but they decided to completely disable integrated graphics to keep CPU temps down, so lowering clocks and voltages seems to be the best way now.
    ROG Member Array
    Nov 2016
    11
    Quote Originally Posted by Matt2097 View Post
    Thanks in advance.
    A pretty good guide. Be sure to check carefully the right voltages.
    https://rog.asus.com/forum/showthrea...575#post618575
    ROG Member Array
    Nov 2016
    14
    There is no need to undervolt the CPU, just have to turn off Intel Turbo Boost Technology since that broken and is the cause of the overheating.
    You can do this by creating a custom power plan in windows and changing the MIN and MAX Cpu usage to 99%, then the turbo will not be used because it only activates at 100%.
    I have been using this method for a while and it works great.
    Source thread: https://rog.asus.com/forum/showthrea...GPU-throttling
