Page 2 of 111 FirstFirst 1 2 3 4 12 52 102 ... LastLast
Results 11 to 20 of 1110
  1. #11
    ROG Member Array
    Nov 2016
    21
    Awesome guide - thanks for taking the time to write/share it.
    Out of interest, if you've checked the "apply at windows startup" icon in the tool, do you need to load up the MSI Afterburner tool, or will it apply the changes silently in the background?
  2. #12
    ROG Member Array
    Nov 2016
    14
    After using this method I had some instability issues (windows randomly crashing on a blue screen)
    So I put these settings back off again, but I think my laptop makes a wierd inconsistent buzzzz sound when idle :/
  3. #13
    ROG Member Array
    Nov 2016
    15
    Thanks for replying , what voltage curve do you recommend me? I'm getting 85 degrees while playing GTA V and Doom :/ .
  4. #14
    ROG Enthusiast Array
    Nov 2016
    34
    Quote Originally Posted by Matt2097 View Post
    Yes, it will apply settings silently. Hold CTRL while logging in to Windows to skip applying Afterburner settings.
  5. #15
    Nov 2016
    34
    Quote Originally Posted by Sfonks View Post
    You have to change the curve one or two voltage steps higher. Open curve by Ctrl+F and drag the leftmost dots (up to 850-875mV) below the main flat line of 1860MHz to i.e. 1800 MHz. This will raise up voltage a bit from 835mV to 850mV for 1860MHz. Click APPLY. Check stability and continue.
    I might update my profile for you with several presets to try.
  6. #16
    Nov 2016
    34
    Quote Originally Posted by hectorbastida View Post
    As every chip is different in quality, you might get better or worse results. My profile is just a starting point, which is stable for me.
    I might update and reupload my profile with several presets for you to try, from most powersaving to more stable. You can select profile in MSI afterburner by clicking 1,2,3,4,5 buttons and click Apply.
  7. #17
    New ROGer Array
    Nov 2016
    3
    Hey onjax, your website is down. I managed to create a profile for my 1060 but I need to see you curve. Can you rehost it? Thanks.
  8. #18
    ROG Member Array
    Dec 2016
    22
    Have you tried repasting the heat sinks?
    Stock thermal compounds are always inferior to aftermarket ones.
    What are you running as well? The GL702VM is supposed to have three fan for better cooling. *
  9. #19
    Nov 2016
    34
    Quote Originally Posted by peggy View Post
    Read my first post pls, I mentioned Liquid Metal was my first idea, didn't help. Asus uses good paste.
  10. #20
    Nov 2016
    34
    Quote Originally Posted by Kaan88 View Post
    Uploaded to google drive LINK
    Use PROFILE selector in MSI Afterburner from 1 to 5 (1 - least heat, but may be unstable for some, 5 - possibly most stable, but more heat)
