Pump and PWM
tistou77
Hello
I have 2 pump D5 PWM (the same) plugged in PWM on the 4pins Water Pump of the R5E10 (blue and yellow file)
Can someone explain me how the PWM works on the R5E10?
Example
60589
I do not know if for 30° for example, it is up to 30°, from 30°
And for Middle and Max ?
Is the PWM related to CPU or CPU Package temperature ?
Thanks for your help
Sorry for my english 😄
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 980 Pro
SOUND: Asus Xonar Phoebus
6 REPLIES 6
Brighttail
Level 11
You have three settings pretty much.
The top is the temperature your CPU will hit when you want your pump to work at 100%. The second and third are the same way. I have the bottom one set on mine at 60% which means pretty much when my computer starts up and as long as the temp is below 50C my pump will run at 60% speed. The middle one I put at 75% for when my CPU temp hits 65C. The top one is if my CPU hits 66C the pump will run at 100%. Of course different people will set their pumps at different rates. Many keep it running at 100% all the time. It is really up to you. I have mine running at 60% most time because it is dead quiet at that level and unless I'm gaming I don't need it to run faster.
Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
tistou77
OK thanks
That's how I set up, but after a while, in idle, I was found with the pumps less than 20% (I think) while the mini was at 60% and 35°
Can be a bug
Otherwise I have the 2 pumps on the same 4pin (Water Pump) connected with a Y
It is better that each pump is connected to a 4 pin or not important ?
Thanks
Case: Lian Li A77F
CPU: i9 10980XE
vmanuelgm
Level 11
Hi Tistou.
I have also 2 pwm pumps (alphacool previous version to latest ones just released) in my RVE, each connected to one 4 pin (cpu and cpu opt) and their respective molex's.
The pumps will reach rpm's according to cpu temperature, if you have a minimum of 30 degrees and 40% for example, the cpu at 30º will make the pumps run at 40% (of 4800 rpm's máximum).
But sometimes when rebooting, I found that RVE (and also RV10) did not manage to control the pumps correctly, letting them almost off and even forcing the bios to show the cpu temperature warning.
Check your "y" cable just in case, and verify the connections are ok.
Best regards!!! 😉
Asus x670e Hero, 7950x, TG 7000, Master 4090, 970 PRO, 860 EVO, Intel 750,
SN850, SN750, 840 Pro, 2xSkyhawk 4TB, Pioneer S12U
EVGA T2 1600, Silverstone TJ11, Custom LC, Acer Predator x35, Philips OLED
tistou77
Hi
And thanks for confirming CPU temperature, I was not sure it was related to that one
The pumps are well connected, I have a flow meter and it is good
I will leave with the Y on the 4pin Water Pump
I regulated like this in the bios
Mini: 60% / 35° (if I set to 30°, even with the CPU at 27°, I'm at the higher speed per moment)
Middle: 80% / 50° (the pumps are between 60 and 80% up to 50°)
Max: 100% / 60° (temperature does not exceed 50° with current ambient temperatures)
Case: Lian Li A77F
CPU: i9 10980XE
vmanuelgm
Level 11
As the other mate mentioned, you have 3 temperature points, max, medium, min and their respective rpm percentages.
If you have max 70-100%, 50-80% and 30-50% for example, the cpu at 30º will run at 50%. Over 30º and until 50, it will increase to 80%; over 50º the same until 70, when the rpm's will be maxed reaching 100%. I am not sure which specific temperature is used, I would bet it needs all the cores over the checkpoint to reach the selected percentages.
In regards to the failure I mentioned, I saw it used to show up when selecting close percentages, for example 70-100%, 50-90%, 30-80%.
tistou77
Ok thanks for the explanation 🙂
I will see to change if it does not go
Case: Lian Li A77F
CPU: i9 10980XE
