12-03-2016 03:08 PM - last edited on 03-06-2024 01:26 AM by ROGBot
12-03-2016 03:52 PM
12-03-2016 04:13 PM
Nate152 wrote:
Hi boneil
When your cpu ramps up to 4200MHz the voltage may increase but you can lower the voltage with a negative offset.
1.184v is fine if your system is stable and your temp is great at 27c, what I'd do now is run a stress test and see where the voltage is when the cpu is under full load. However much it's going over 1.20v you can use a negative offset to counter the voltage overshoot.
You can use ROG CPU-Z or HWinfo for cpu voltage monitoring if you don't have a cpu voltage monitoring program.
ROG CPU-Z
Scroll to the top and click "setup" in the ROG version, then click download now and click run.
http://www.cpuid.com/softwares/cpu-z.html#version-history
HWinfo - I see your OS is N/A
https://www.hwinfo.com/download.php
ROG Realbench for stress testing, click Stress test beside Benchmark, select how many GB of ram you have, the 15 minute test is fine.
http://rog.asus.com/rog-pro/realbench-v2-leaderboard/
You can switch the cpu core/cache voltage from manual mode to adaptive mode and enter your voltage (1.20v) in the "Additional Turbo Mode cpu core voltage" then just below that enter in the negative offset. Just subtract how much it's going over 1.20v during the test and enter it in the negative offset, this should put you at or very close to 1.20v
12-03-2016 04:28 PM
12-03-2016 04:40 PM
Nate152 wrote:
You're welcome
Question 1 - It seems you have a very good 6700k if it's only using 1.18v when setting 1.20v. You can use a positive offset of + 0.016v to put you at 1.20v but I wouldn't if it's happy with the lower voltage. It's something to be happy about more than concerned with. 🙂
Question 2 - You are correct the cpu voltage will not throttle down when in manual mode is why I suggested to use adaptive mode. Do you have turbo enabled?
12-03-2016 04:52 PM
12-03-2016 05:07 PM
12-03-2016 05:10 PM
