G551JW Right-side USB port and audio jack not working after disassembling
Sasasa
I guess the title says it all. I took my laptop apart to fix a problem with the right speaker. when listening with loud volume, the case starts resonating and that started to get really annoying. But now after getting everything back together, my right-side USB port and audio jack next to it arent working. USB port still gives power but doesnt recognize any devices. Does anyone have an idea how to fix this? I already tried re-installing drivers.
Thanks.
Clintlgm
Level 14
Yes you are answering you own question. Something is not assembled correctly or something has been broken which is not good since I think the right side USB and other port are soldered on the Motherboard not sure this is true on 15" models 17" models right side modules are soldered. yours may be different and you just didn't get a cable correctly installed? ofr bent a pin?
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
