G750JW Linux, Only Subwoofer Audio Output
airatin
As per the title, only the subwoofer has any audio output in my dualboot Linux. Speakers work fine in Windows. I've tried changing Mono/Stereo in PulseAudio to no avail. What to do?
Here is my alsamixer:
60777
Here is my output of inxi -Fxxx:
System: Host: alborz-G750JW Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
Desktop: Cinnamon 3.0.7 (Gtk 3.18.9) dm: mdm Distro: Linux Mint 18 Sarah
Machine: System: ASUSTeK (portable) product: G750JW v: 1.0
Mobo: ASUSTeK model: G750JW v: 1.0 Bios: American Megatrends v: G750JW.210 date: 12/11/2013
CPU: Quad core Intel Core i7-4700HQ (-HT-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19157
clock speeds: min/max: 800/3400 MHz 1: 2617 MHz 2: 2719 MHz 3: 3109 MHz 4: 3216 MHz 5: 3051 MHz
6: 2859 MHz 7: 3100 MHz 8: 2760 MHz
Graphics: Card: NVIDIA GK106M [GeForce GTX 765M] bus-ID: 01:00.0 chip-ID: 10de:11e2
Display Server: X.Org 1.18.4 driver: nvidia Resolution: 1600x900@60.06hz
GLX Renderer: GeForce GTX 765M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 375.20 Direct Rendering: Yes
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Card-2 NVIDIA GK106 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0e0b
Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network: Card-1: Broadcom Limited BCM4352 802.11ac Wireless Network Adapter
driver: wl bus-ID: 03:00.0 chip-ID: 14e4:43b1
IF: wlp3s0 state: up mac: 6c:71:d9:36:60:b4
Card-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
driver: alx port: d000 bus-ID: 04:00.0 chip-ID: 1969:10a1
IF: enp4s0 state: down mac: 74:d0:2b:e9:4c:c8
Drives: HDD Total Size: 2512.5GB (2.0% used)
ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB serial: S2Y4J9FD404111
ID-2: /dev/sdb model: ST1000LM024_HN size: 1000.2GB serial: S2Y4J9FD404103
ID-3: /dev/sdc model: Samsung_SSD_850 size: 512.1GB serial: S1SXNSAFA14082N
Partition: ID-1: / size: 202G used: 34G (18%) fs: ext4 dev: /dev/sdc6
ID-2: swap-1 size: 16.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdc8
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 49.0C mobo: N/A gpu: 0.0:44C
Fan Speeds (in rpm): cpu: 2300
Info: Processes: 246 Uptime: 23:14 Memory: 12375.1/15997.0MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Shell (bash 4.3.421 running in gnome-terminal-) inxi: 2.2.35
6 REPLIES 6
airatin
bump
atharvahude
same issue any updates?
Have you tried pipewire, with the pipewire-pulse package?
No does it work ?
I dont know, its easy to try. But if you get the same errors in `dmesg -T` as in the link you sent then it wouldn't help (don't post all of it online, but you can e.g. add `| grep 'Platform not supported' `)
