Results 1 to 1 of 1
    ROG Member Array
    May 2015
    6
    Maximus VII Formula DRAM Voltage Low 0.334V
    Hello guys im not sure if this is a major issue, But it seems my Corsair Vengeance Pro CMY16GX3M2A2400C11 2x8gb's have an extremely low voltage its currently running in XMP on the bios at 2400mhz speed, both readings on Asus AI Suite II & The bios report that the Voltage is in red on the bios at 0.334V does this sound like the Memory is faulty, I Dont see any anomaly however while gaming everything seems to be ok, Does this seem like a major issue ? Click image for larger version.
