Results 1 to 5 of 5
    Top ROG Fan of 2016 Array adiath PC Specs
    adiath PC Specs
    Laptop (Model)ASUS A46C
    MotherboardASUS Z-170 I Pro Gaming
    ProcessorIntel Core I5 6600K
    Memory (part number)ADATA XPG DDR4
    Graphics Card #1ASUS Strix GTX 950
    Graphics Card #2Radeon R7750
    Storage #1Kingston Hyper X SSD
    Storage #2HDD Western Digital Caviar Blue
    CPU CoolerDeepcool Gamaxx 400
    Power SupplyEnermax NAXN 450W
    Mouse ASUS ROG Gladius
    Headset ASUS ROG Orion & Creative SoundBlaster Tactic 3D Alpha
    Mouse Pad ASUS 10th Anniv Edition
    OS WIndows 7
    Network RouterASUS Wireless Router
    Jun 2016
    20
    Lightbulb Basic Guide - Overclocking Intel Core i5 6600K 'Skylake' using Asus Z170i Pro Gaming
    Hi guys, whats up!!! Haha
    Now i want to share basic guide how to overclock Intel Core i5 6600K 'Skylake' using Asus Z170i Pro Gaming. I just do some basic overclocking here, so i hope new overclockers can understand. In this basic gude, i will explain how to overclock Intel Core i5 6600K to 4.5GHz using Asus Z170i Pro Gaming Motherboard (should be aplicable to other Asus Z170 motherboard).
    My System Specification :
Name:	IMG_0906 - Copy.JPG
Name:	IMG_0912 - Copy.JPG
    Hardware :
    Processor Intel Core i5 6600K
    Motherboard Asus Z170i Pro Gaming
    Memory DDR4 Patriot Viper 8GB (2x4GB) 2400MHz CL-15
    PSU Enermax Naxn 450 Watt
    SSD Kingston HyperX 128GB
    AIO Water Cooling Corsair H110
    Software :
    Official BIOS from Asus
    OS Windows 7 64Bit
    CPU-Z 1.77 ROG
    Cinebench R15
    1. Power on your PC and press 'Del' immediately to enter BIOS.
    2. Press F7 to enter Advance Mode
    3. Go to 'Ai Tweaker' menu
    set 'Ai Overclock Tuner' to 'Manual',
    set 'BCLK Frequency' to '100' (Default)
    set 'CPU Core Ratio' to 'Sync All Cores'
    set '1-Core Ratio Limit' to '45'
    * so we set Core ratio 45 and BCLK frequency 100 will make 45 x 100 = 4500 MHz = 4.5 GHz
    4. Scroll down 'Ai Tweaker' menu
    set 'DRAM Frequency' to 'DDR4-2800MHz'
    5. Scroll down 'Ai Tweaker' again
    set 'Min CPU Cache Ratio' to '43'
    set 'Max CPU Cache Ratio' to '43'
    set 'CPU Core/Cache Voltage' to 'Manual Mode'
    set 'CPU Core Voltage Override' to '1.300' (1.3 Volt)
    set 'DRAM Voltage' to '1.500' (1.5 Volt)
    * or you can leave voltage to auto if not sure
    6. Go to 'DRAM Timing Control' sub menu and press enter
    set 'DRAM CAS# Latency' to '13'
    set 'DRAM RAS# to CAS# Delay' to '18'
    set 'DRAM RAS# ACT Time' to '28'
    set 'Command Rate' to '2'
    *we set Primary Timings to 13-18-18-28 2T. Or if you not sure, you can leave all primary timings to 'Auto'.
    7. Go to 'Advanced' menu > 'CPU Configuration' > 'Q-Fan Configuration'.
    Disable 'CPU Q-Fan Control'
    Disable 'Chassis Fan 1 Q-Fan Control'
    Disable 'Chassis Fan 2 Q-Fan Control'
    * we disable fan control to get maximum performance from our Fans
    7. Go to 'Advanced' menu > 'CPU Configuration' > 'CPU Power Management Configuration
    Disable Intel(R) SpeedStep(tm)
    Disable CPU C states
    Disable CFG lock
    * we disable power management to optimize overclocking
    8. Press F10 to save and exit BIOS and enter Operating System.
    After entering Windows, check your current overclocking result using CPU-Z.
    9. Do some benchmark to compare your PC performance when running on default and when running after overclocking.
    I'm using Cinebench R15 (Multithreads image rendering benchmark) to compare default performance with overclocked performance of my system.
    On default, i got 605 point, after overclocking, i got 756 point. Thats mean i got about 25% faster performance on my light overclocked PC (on multithreads image rendering scenario / Cinebench R15).
    * to set your system to default setting after overclocking, enter BIOS, press F5, press F10
    So, how about your PC Performance? Keep pushing it!!!
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,823
    Thanks for your tutorial. looks interesting. Question Why 43 in the mim and max on the CPU ratio. Disable the Q-Fan for max performance will put the fans on full speed? *I get the part adding the ram timings from factory. I have to change my cooler these week (115i) since my deep cool on my 6700K is not doing the correct job. A friend of mine help to make my processor on the Asus work. On he GA, I was on 4.6 at 1.381 ultra stable. here took me more more time 3 RMA and testing a Alpha that appears to be ok I think. No Asus apps are install. (known issues) As soon I recibe my 4 RMA..... I will start again with all os and OC again.*
    adiath PC Specs
    OS WIndows 7
    Jun 2016
    20
    Quote Originally Posted by Itzycharles View Post
    43 for min & max, for cache cpu ratio, so we set manually cpu cache ratio to 43. 43 isn't cpu core ratio. Yes, as i know, when we disable Q-Fan controller, system set to max performance (full speed). CMIIW.
    Yeah, waiting you can start OC again and share your results here,
    ROG Enthusiast Array Michael-i7 PC Specs
    Michael-i7 PC Specs
    MotherboardAsus z170 Deluxe
    Processor17-6700k 4.7 Ghz 1.385v De-Lid
    Memory (part number)32gb 3333Mhz Dominator Platinum
    Graphics Card #1Evga 1080 Ftw Hybrid 2139 Mhz
    MonitorAsus mg279q 1440p 144hz
    Storage #1256gb 950 Pro m.2
    Storage #24tb hdd
    CPU Coolerh100i v2
    CaseCarbide 400c
    Power Supplyrm850i
    Keyboard Razer Blackwidow Chroma
    Mouse Razer Naga Chroma
    Headset G430
    OS 10 Pro
    Dec 2016
    54
    Cache
    I have the i7 6700k in an Asus z170 Deluxe I have mine overclocked to 4.5Ghz with 1.31v and I have my min/max cache 45 as well and I'm stable as F. And I must point out that with ddr4 DO NOT put the voltage at 1.5v I have my ram overclocked to 3333Mhz with 1.355v ddr4 is 1.2-1.35v ddr3 was 1.5 You may not kill your ram that way but the chances are very good that you will there is no need to put ddr4 over 1.35-1.4 especially at a meager speed of 2800mhz even 4000 mhz ddr4 isnt rated at 1.5v
    adiath PC Specs
    OS WIndows 7
    Jun 2016
    20
    Quote Originally Posted by Michael-i7 View Post
    Yes, i agree for daily OC, 1.5V is too high. I should recomend to use 1.4V in this guide. Thanks for you correction.
    But, my reason to choose 1.5V is maybe another person will use higher clock & tight timing, and every ram have different capabilities in OC.
    In competitive OC, you will find many OCers use more than 1.7V (also more than 1.8V), because they know how to use high voltage in some scenario for reach high frequency & tight timings.
Tags for this Thread
