Results 1 to 7 of 7
    New ROGer Array lmntrix PC Specs
    lmntrix PC Specs
    Laptop (Model)ASUS ROG G752VY
    MotherboardG752VY
    Processorintel® core™ i7-6820hk (2.7 ghz)
    Memory (part number)64 GB DDR-4
    Graphics Card #1Nvidia® Geforce® GTX 980m 8GB GDDR-5
    Monitor17.3" UHD - No glare - Led - IPS
    OS Windows 10
    Nov 2016
    4
    Exclamation G752VY (64GB) - Help needed, ROG GAMING CENTER Overclock 'EXTREME' issues - solved?
    Hi guys, I need your help if possible.
    I bought 2 weeks ago ASUS ROG G752VY:
    - Windows 10 /
    - 17.3" - 3840x2160 pixel - uhd- no glare- led- ips /
    - intel core i7-6820hk /
    - 64GB RAM /
    - nvidia geforce gtx 980m /
    - 1 tb 7200 rpm + 1tb ssd g3x4
    it's a very wonderful Laptop but I've some problem :
    By default, ROG GAMING CENTER sets the Overclock performance on "EXTREME" when it works in AC mode, unfortunately, when I try to play to Final Fantasy XIV, after 10-15 minutes the screen comes completely white with multi-color vertical lines; so, the system freeze and I need to restart the laptop using power button.
    If I change the Overclock from EXTREME to STANDARD All games work fine and this problem seems fixed, consider that i played on EXTREME mode at WOW and nothing happened, only with new games in directX11 this happens.
    Following your experience what can i do to play best without risks? Is this a problem of the Laptop?
    I think that is strange that asus put as standard an EXTREME OVERCLOCK mode if the system doesn't resist.
    Ho can I set the best overclock for this model? someone encountered this problem?
    BIOS already updated to the latest version
    GPU updated to the latest version.
    Thank you for you help.
    Carlo.
    Super Moderator Array
    Jan 2013
    99
    2,133
    Welcome to the forums!
    Not sure how much this will help for the G752VY, but think it's worth a try to update the Turbo Gear software for the ROG Gaming Center as in the G752VS thread below.
    The ASUS G752VY download site also posted the new Turbo Gear software under the Win10 'utilities' section.
    If it doesn't help, please let us know to see if others have better ideas. Thanks.
    https://rog.asus.com/forum/showthrea...Overheat-Issue
    lmntrix PC Specs
    MotherboardG752VY
    OS Windows 10
    Nov 2016
    4
    Updated Turbo Gear using ASUS UTILITIES, on official website.
    - Tested with World Of Warcraft : No issues, it works fine in EXTREME configuration.
    (Waiting to test with Final Fantasy XIV : Online [DirectX11])
    Also, I noticed that the air intake on the left generates more air than air intake on the right, is it normal? It depends by position of the GPU? I ask because I cannot open the bottom to check, is better not open that box see image below.
    ROG Enthusiast Array
    Nov 2016
    56
    Quote Originally Posted by lmntrix View Post
    there's two fans as far as I've known with my G752VT, fairly normal for it to do that. You could check what's running just by running ROG Game Center (if you can) and placing your hand over either of the exhaust vents to tell which has more air flowing.
    lmntrix PC Specs
    MotherboardG752VY
    OS Windows 10
    Nov 2016
    4
    Quote Originally Posted by Digimutant View Post
    Yes, thank you, checked and in fact with ROG Game Center active I confirm that on the left (seeing monitor) this side has more air flowing, the right side has less air flowing, so, it could be normal, no issues, if I understood correctly.
    Regards.
    Carlo.
    lmntrix PC Specs
    MotherboardG752VY
    OS Windows 10
    Nov 2016
    4
    Tested also on Final Fantasy XIV DirectX11.
    Graphic set up : MAXIMUM
    Benchmark : >7000 (extremely High performance supported)
    Resolution : Full HD Fullscreen (1920x1080)
    ROG GAME CENTER SET UP : Extreme.
    Graphic set up : High (Laptop)
    Benchmark : >24000 (extremely High performance supported)
    I played for more or less 1h and the system didn't crash.
    So, For this time I confirm that Turbo update seems work fine and seems fix the issue.
    I keep you updated for news.
  7. #7
    New ROGer Array
    Oct 2017
    7
    Sorry for the inconvenience but i have a G752VY laptop but dont have on gaming center turbo gear or something else i try once to run a setup of turbo gear but i cant, am i doing something wrong?
