Results 1 to 7 of 7
    ROG Member Array
    Jul 2016
    13
    Question Rampage V Edition 10 with Corsairs PSU AX1500i and H115i cooler
    Anyone using the AX1500i Link Digital Interface connected to the H115i?
    Should i do it?
    How did you choose to plug those two to the RVE10?
    Thanks in advance!
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,336
    I have a 1200i and don't use the link software. I used to but honestly it clashes with the Asus Suite III. If you want to use the colours on the block then you simply connect the AIO to the Link and the block portion to a USB header. It will work fine but I would suggest uninstalling the Asus Suite. The Link software is also buggy and doesn't hold settings very well.
    The problem is the LINK software isn't great for fan speed control. You can just use BIOS control over the fans tho. In the end it is about what you want. If you want colour, use the link software. If you don't care about the lighting you can install the link, set the colour you want, uninstall and the colour on the block should hold.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
    ROG Guru: White Belt Array Catalonia PC Specs
    Catalonia PC Specs
    MotherboardAsus Rampage V Eddition 10
    Processori7 6850k Broadwell-e @ 4.3GHz
    Memory (part number)G.Skill Trident Z DDR4 3200MHz CL14 32GB 4x8GB
    Graphics Card #1Asus Strix 1080 Ti OC
    MonitorAsus ROG Swift PG279Q 165Hz G-Sync IPS
    Storage #1Samsung SM961 M.2 512GB NVME
    Storage #23TB WD RED
    CPU CoolerCorsair H150i PRO
    CaseCorsair 780T Black
    Power SupplyCorsair AX1600i
    Keyboard Corsair K95 Platinum
    Mouse Logitech G903
    Headset Audio Technica DSR9BT
    Mouse Pad Corsair MM800 Polaris RGB
    OS W10
    Network RouterAsus GT-AC5300
    Sep 2015
    92
    I have this exact confoguration.
    6850k, Asus Rampage V Edition 10, Corsair H115i,
    I also use the latest Corsair Link software, as I don't really enjoy Asus ai Suite (too buggy).
    Catalonia PC Specs
    Mouse Logitech G903
    OS W10
    Sep 2015
    92
    Quote Originally Posted by Catalonia View Post
    By the way, since I don't have enough internal USB for conencting the devices, I bought an internal USB Hub:
    This one: https://www.amazon.es/gp/product/B00...?ie=UTF8&psc=1
    Which works perfectly well and is easy to hide.*
    ROG Guru: Orange Belt Array Legolas PC Specs
    Legolas PC Specs
    MotherboardMaximus X Hero Wifi AC
    ProcessorIntel Core i7 8600k oc 5Ghz
    Memory (part number)Samsung DDR4 16GB
    Graphics Card #1ASUS NVIDIA GTX 1080
    MonitorASUS MS246
    Storage #1Samsung MZVPV256
    Storage #2Samsung MZVPV256
    CPU CoolerCorsair H110I v2
    Power SupplyPC 1200W Turbo-Cool 1200
    Keyboard ASUS SK2045
    Nov 2015
    250
    I have no issues with Corsair LInk with Ai suite 3. Only need to let Corsair control the water pump and AIO Water cooler and plug the 3pin of water cooler to the Water_Pump to control the speed. USB of the H115i to the USB 1112
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,856
    I had the H115I that I took out and going to put it on the block for sale.
    Had the link software running with the AIO and PSU on it. Had them both using USB headers.
    No issues with conflict with AI suite. Only used the link to control the fans on the rad. The PSU does its own thing and the fan rarely turns on.
    The only thing that I did was default has the link software using CPU temp to control the fan speeds. That will run you in the crazy house! Be sitting there all nice and quiet then out of nowhere the speed jacks to 100% for a few seconds. Just change that to use the liquid temps as a reference and set a curve to your liking. Had mine at like 25% up to 30C then 40% at 32C and 100% at 35C. Yes short loop but if my Liquid temp gets up over 32C things are heating up and it will only continue to climb.
    Ive since yanked the H115i and went to a full Liquid cooled system that AI suite is controlling fairly well. Just bit the bullet and spent $$ I didnt really need to for a Aquaero 6 pro for pump and fan control. That will be here tomorrow and Ill spend the next week trying to figure it out. Biggest reason for that is I want to be able to measure flow in my system and flow meters report rpms but nowhere does that get converted to a flow rate. I should be able to incorportate that along with the liquid loop temp for better pump control.
  7. #7
    Catalonia PC Specs
    Mouse Logitech G903
    OS W10
    Sep 2015
    92
    Quote Originally Posted by JustinThyme View Post
    Pump control is what I actually miss from H115i and Corsair Link Software. Is not possible to set a lower rate in low temps and increase it in higher temps. Is either low or high all the time.
Tags for this Thread
