Results 1 to 3 of 3
    ROG Member Array
    Mar 2016
    5
    Exclamation G551JW Caps Lock and Fn key not working
    For some reason today when I booted up my G551JW, the Caps Lock and Fn key no longer seem to work. Caps Lock doesn't light up the indicator, Fn key isn't allowing me to change volume/brightness/etc.
    I have tried uninstalling/updating ATK Package and Uninstalling the listed Keyboards under Device Manager.
    Any help would be highly appreciated!
    Thanks
    ROG Guru: Yellow Belt Array
    Jun 2016
    23
    150
    The keyboard itself could be failing. My screen and keyboard (G752VY) had to be replaced after only 5 months... If its still under warranty, the ASUS repair center will change it with no fuss. Took them only 3 days in my case.
    ASUS HQ Service Rep Array Bill@ROG's Avatar
    Dec 2015
    433
    Hello holdsh1ft
    I would also recommend sending your unit for RMA
    Please contact your local Asus help line or repair center near you for further assistence
    Thank you
Tags for this Thread
