Results 1 to 3 of 3
    New ROGer Array
    May 2016
    2
    Max Resolution with External Monitor on G501VW @60Hz ??
    Hello!
    I have a G501VW-76B96PB1 with 4K display and the following specifications:
    CPU: 6th Generation Intel® Core™ i7-6700HQ Quad-Core 2.6 GHz with Turbo 3.5 GHz 6 MB Cache
    Chipset: Intel® HM170 Express
    RAM: 16GB (8GB onboard + 8GB) DDR4 2133 MHz
    Display: 15.6" LED Back-lit Ultra Slim 300nits UHD 3840X2160 16:9 Anti-Glare NTSC: 72%
    GPU: Intel® HD Graphics 530 + NVIDIA® GeForce® GTX960M 4GB GDDR5
    Storage: SSD M.2 512GB PCIEx4
    Card reader: Leitor de cartões 2 -em-1 (SD/ SDXC/ MMC)
    WebCam: HD Web Camera
    Communcations: Wireless 802.11ac + Bluetooth 4.0 (Dual band) - WIDI
    Interface:
    1 x Microphone-in/Headphone-out jack
    1 x Port USB 3.1 TYPE C (gen 2)
    3 x Ports USB 3.0
    1 x HDMI 1.4
    Audio: Colunas Integradas e Microfone Bang & Olufsen
    I'd like to know the maximum display resolution for an external monitor (only one) at 60 Hz. Is it possible to have another 4K screen at 60 Hz refresh rate? What is better, HDMI or Thunderbolt 3?
    Thanks
    ROG Enthusiast Array Sheltem PC Specs
    Sheltem PC Specs
    Laptop (Model)ASUS G752VS-GB139T
    MotherboardASUS Prime X299-Deluxe II
    Processori9-10900X
    Memory (part number)F4-3466C16Q-64GTZKK
    Graphics Card #1MSI RTX 2080 Ti Gaming X Trio
    Graphics Card #2some 3080 Ti, whenever it launches
    Monitoracer Predator X34 (Curved 34", UWQHD 3440x1440@100Hz, IPS, G-Sync)
    Storage #11TB Samsung 970 Pro
    Storage #22TB and 500GB Samsung 860 EVO
    CPU CoolerNoctua NH-D14
    CaseCorsair Carbide 678C Low Noise ATX
    Power SupplyEVGA SuperNOVA 1200 P2
    Keyboard Logitech G910 (Orion Spark)
    Mouse Logitech PRO
    Mouse Pad Logitech G440
    Headset/Speakers Edifier S330D
    OS Windows 10 Pro (64-bit)
    Network RouterMikroTik RB1100AHx4
    Accessory #1 Linksys WRT1900AC (Stock OS, WiFi AP-only bridge)
    Accessory #2 TP-LINK SG1005D
    Dec 2016
    16
    74
    Quote Originally Posted by hacdias View Post
    Thanks
    HDMI version 1 cannot handle 4K resolutions at 60Hz. It COULD handle 4K at 30Hz or less, assuming the graphics card that you are going to connect it to has proper support for such a configuration (problems with that may be observed on Optimus-enabled laptops, though, and yours should have the integrated graphics disabled altogether).
    You would need to confirm that both the graphics card and the external monitor support HDMI 2.0 or above to use this port.
    Thunderbolt is essentially an "improved" (layman's terms) DisplayPort, thus this port will definitely be able to handle 4K @ 60Hz, assuming the connecting cable itself is able to (some lower quality DP cables that are advertised as 1.2 might pose an issue).
    Assuming HDMI 1.4 or lower and only one DP 1.2 compatible port* on the card, this would mean only one external screen.
    * - Any of DP 1.2, 1.3, 1.4 and Thunderbolt are compatible (more info)
    New ROGer Array
    May 2016
    2
    Thanks! THat's all I wanted to know
Tags for this Thread
