Results 1 to 7 of 7
Thread: help with mobo
    ROG Member Array sharook1986 PC Specs
    Motherboardasus maximus v formula
    Processori7 3770k
    Memory (part number)corsair vengeance 2x8gb ddr3 1600mhz corsair xms 2x4gb ddr3 1600mhz = 24gb
    Graphics Card #1asus strix gtx 970
    Storage #1ocz vector 120gb
    Storage #2western digital blue 1tb
    CPU Coolercorsair h75
    Casecorsair carbide 300 series
    Power Supplycorsair cx750m
    Keyboard micrisoft sidewinder x6
    Mouse micrisoft sidewinder x5
    Headset turtlebeach px22
    OS windows 10 64 bit
    Dec 2016
    8
    help with mobo
    hi there ive recently just purchased a i7 3770k cpu and a sus rog maximus v formula mobo what the problem is is im running a gtx 970 on the board and when i put it in the pcie slot1 it shows up as 2.0 x16 not 3.0 x16 like it should be if i put the gpu into slot 2 it shows as 3.0 x8 but if i put it back into slot one it still showing as pcie 2.0 not 3.0 can anybody help as to why i cant set it in the bios to gen3 and run it as 3.o like it should be it very frustrating lol
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hi sharook1986
    Install GPU-Z and see what it's showing, it shows mine at pcie x16 3.0 @ pcie x16 1.1
    When I put a load on it, it ramps up to pcie x16 3.0
    Click the pics to make them bigger.
    Idle
    Load
    Attachment 61183
    Processori7 3770k
    Dec 2016
    8
    for some reason every now and then it also runs in 4x i really dont get this
    Processori7 3770k
    Dec 2016
    8
    heres another but this time it says 2.0 x16 i dont get it ive changed it in the bios and it jus wont show on my display when set in gen 3 if i put the gpu in slot 2 it runs in 3.0 x8 so i know the 3.0 working i jus dont think it working properly on this mobo unless im doing something wrong
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Try reseating your GTX 970.
    Processori7 3770k
    Dec 2016
    8
    Ive reseated it a few times and still no luck
  7. #7
    Processori7 3770k
    Dec 2016
    8
    just an update at least one or 2 of the socket pins ave broke off or something (what u get for buying a secondhand board) anyways thats why so need to see if can get socket repaired now
