Results 1 to 10 of 10
    ROG Member Array
    Apr 2016
    7
    Memory selection for Maximus VIII Extreme, confused
    So I am running the Asus M8E with 6700k, 3 EVGA 1080 GTX FTW ACX 3.0 cards, Noctua NH-D15 air fan setup until i decide to water-cool, I haven't made a decision on the storage as of yet, prob, Samsung 950's.
    But the memory is where I am confused on.
    when reading the QVL list how am I to get the the Max memory 64gb, at the highest speed 3866, or what I am missing here...what is the best memory to install at the stock speed then OC this up to those fast speeds 3333, 3400, 3466, ....up to 3866 etc. Does this mean I order what seems to the be the fastest at 64gb
    (G.SKILL
    F4-3400C16Q-64GTZ
    64GB (4 x 16GB)) and then OC from there.....
    Or getting Kingston memory HX426C15FBK2/16 .....16GB ( 2x 8GB ) and then over clock this to 3866 or am i missing how this works....
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hi TfastME8
    If you want super fast ram you'd be better off going with a 16GB kit and even then it will be up to the cpu's integrated memory controller if it can handle it, nothing is guaranteed except for 2133MHz.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Quote Originally Posted by 1fastME8 View Post
    (G.SKILL
    F4-3400C16Q-64GTZ
    I'm running that HyperX FURY 2666MHz kit with my Maximus VIII Extreme actually. Couldn't be happier.
    ROG Member Array
    Apr 2016
    7
    So should I be concerned with getting 64gb out of the system or 16...?
    I was looking up the
    [URL="http://www.gskill.com/en/product/f4-3400c16q-64gtz"]
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Good question haha
    You'll get 2 different stories from me and Chino, he likes more ram at a lower speed while I prefer less ram with a faster speed. Ram isn't a big perforrnance deciding factor, if you're just gaming 16GB is enough. If you use programs that use alot of ram then it would make sense to go with more ram.
    G'Skill's prices are on the rise.
    You probably won't find a faster 16GB 3200MHz kit with CL14, you could get this and overclock it but when you have to loosen the timings to gain frequency you don't gain much.
    16GB is plenty even with three 1080's.
    http://www.newegg.com/Product/Produc...-409-_-Product
    Oct 2012
    339
    15,255
    It's up to you and what you do with your system. If you need 64GB, go ahead and get it.
  7. #7
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Im running Gskill trident 3400Mhz 64GB kit. it will run at 3400 with no problems it will also run at 2133 no problem and everything in between. Ive had my CPU to just past the 5Ghz barrier with this memory at 3460 with 1.375 (rated for 1.35) Vram with ram WC. BCLK set to 104.85 and cpu multiplier to 48 at 1.495 Vcore for an OC to 5.032 Ghz.
    Plicked the Ram right off the vendor list.
    http://www.newegg.com/Product/Produc...82E16820232260
    It looks like this now though after adding water cooling......before/after
    FWIW if you go WC dont pay attention to the buffoons saying to pry off the heat spreader with a precision screw driver. They need to be smacked for publishing that crap. A little heat with a heat gun and prying between with a plastic card (hotel key card LOL) and the spreaders popped right off and left no residue to clean up like the prying method does and it doesnt leave any tool marks.
  8. #8
    ROG Member Array
    Apr 2016
    7
    Awesome Thank you for the insight on this.
    I will be running both games and various programs that I would deab the machine to be a hybrid of workstation jobs and gaming as well.
    I got my 3rd GTX 1080 FTW card in and my heat sink. For now I went with the Noctua NH-D15 air fan setup until i decide to water-cool.
    Memory I think im sold on the trident Z F4-3400C16Q-64GTZ.
    Now,
    Heres the flip side. LOL as there always is.....I just received my 10 anniversary ed asus Motherboard which seems like you can take the Intel® LGA 2011-v3 little further with running the intel 6950x and 128gb of ram etc....
    I know as always, it depends on its purpose...but wether running a game at top notch or CAD, rendering video graphics, making a video, while running a file, server, playing music etc. The best speeds and performance should always yield the best results against any process....correct?
  9. #9
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Samsung B-die chips work equally well on Z-170/Z-270 and X-99 systems
    The only way I know how to tell if they are B-die is the first 3 timings are the same
    Gskill 3200 mhz 14-14-14, 3600mhz 16-16-16, Corsair Vengence 3600mhz 16-16-16
    I have not tried the Corsair kit but the Gskill kits work very well in my systems at XMP and overclock very well
  10. #10
    ROG Junior Member Array
    Dec 2017
    3
    I just OCed 4X8GB (32GB) HyperX 2400 CL12 to 3100 CL15 at 1.38V. The computer got a fresh breath I can tell. I can also see it in Passmark, CPU score from 12400 to 13330, GPU from 15200 to 16500. What is the fastest currently available RAM I could consider on that motherboard?
