Results 1 to 3 of 3
Thread: usb 3 help
    New ROGer Array
    Nov 2011
    4
    usb 3 help
    before i had a asus notebook n71ja and usb 3 was just working fine i use my vabatim store and go 500gb usb 3 and it run fine
    now i got a asus notebook g74s whem i try to run my vabatim store and go it dont run in usb3 when i try usb 2 it fine
    i try all the usb 3 driver you got here but it dont work in usb 3 mode is the any body here ho can help thanks
    jj2
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Go into the BIOS setup and under the Advanced menu set USB Charge to enable and see if that helps.
    Let us know, OK?
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    Oct 2011
    31
    2,916
    Also, a simple but easily-overlooked point....make sure you're using the one USB 3.0 port. It's the one on the right side, with the blue tab. You said you tried "all the USB 3 drivers." I'm not sure which ones or how many that includes, but uninstall all of them and just use Fresco 3.5.4.0.
