Results 1 to 2 of 2
    ROG Enthusiast Array
    Jul 2014
    56
    G752VL buttons questions and quality of plastic
    Hello,
    1. How can I switch profiles 1/2/3 for the M1, M2, M3 ... keys without using the software ? Is there a hardware key like on Logitech keyboards ?
    2. What is that ROG key where usually is Num Lock ? Can I set it to be Num Lock ?
    3. I've received yesterday my notebook and today I've noticed that on a corner the paint is wear out.
    https://s30.postimg.org/lqensxahd/20...9_10_57_47.jpg
    Does anyone have also small issues like this, being an issue in the long run and it's not worth it to send it back for warranty ? Or this should be perfect and the paint should stay ?
    Thanks
    Jul 2014
    56
    Anyone ?
