Results 1 to 5 of 5
    ROG Member Array
    Apr 2015
    12
    Asus G751JY battery replacement
    I'm having the dreaded battery issue on my laptop and I decided that now is the time to replace the battery. The issue is that I don't know where I should buy the battery from. Can anyone recommend a site on where I can buy the battery replacement? I tried searching, but couldn't find a specific site.
    Thanks!
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    There are plenty out there. The issue is if you want OEM.
    Amazon is flooded with Chinese replacements. Take your pick
    https://www.amazon.com/s/ref=nb_sb_n...s+battery+G751
    If you want OEM the only place I know if is in Europe but they ship worldwide, Ive ordered parts from them before.
    A bit pricier but genuine OEM parts.
    http://www.asusparts.eu/en/Asus-0B110-00290000
    ROG Member Array
    Apr 2015
    12
    Quote Originally Posted by JustinThyme View Post
    I think I should fork the extra cash and go with OEM.
    Thanks!
    ROG Enthusiast Array mpgioia's Avatar
    Sep 2015
    34
    4 years on.. there's literally no way to source an OEM battery for the G751JY .. anywhere in the world ? Regardless of what I want to pay ?
    New ROGer Array
    May 2020
    3
    Sure, you can send your laptop to a certified repair partner and you will get an OEM battery. ASUS does not sell spare parts to private customers.
