Questions about G752VT warranty/RMA after slight water damage
kingswillz
Today, I accidentally spilled a little bit of water on my touchpad and now the right-click button is not working at all.
Everything works fine, no issues, touchpad is behaving normal and the left-click is also normal. No other issues.
Its been 9 months since I bought the laptop. Am I still able to send this for repair/RMA? Or does this not fall under the warranty?
Also, I bought this at a store, not directly from Asus. I have registered my product on the ASUS site as well if it matters.
I have no idea what I can do right now. My model is G752VT and all my drivers are updated.
Clintlgm
Level 14
Yes you can RMA, unless you have ADP and you might have it. it won't be covered, Most of these are sold with 1 Yr warrant and 1 Yr ADP you'll have to check with Support or your purchase invoice to see if your retailer had this on it or not?
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
