Results 1 to 2 of 2
    ROG Member Array
    Dec 2015
    11
    G751JY - CPU hardware upgrade possible?
    Is it possible to replace my Intel Core i7-4720HQ CPU with a more powerful CPU ???
    ROG Guru: Green Belt Array Dreamonic PC Specs
    Dreamonic PC Specs
    Laptop (Model)ASUS GX800VH-XS79K
    MotherboardASUS GX800VHK (Intel CM238/IDA154) w/Custom BIOS
    ProcessorIntel Core i7-7820HK @ 4.8Ghz (+150mV) FCBGA 1440
    Memory (part number)64GB (PC4-22400) @ 18-18-18-38-53 (76.D305G.D060B)
    Graphics Card #1NVIDIA GeForce GTX 1080 8GB (GP104) OC @ +200/+800 w/Custom VBIOS
    Graphics Card #2NVIDIA GeForce GTX 1080 8GB (GP104) OC @ +200/+800 w/Custom VBIOS
    MonitorASUS PG348Q 34" 3440x1440 @ 100Hz w/G-SYNC (mDP-to-DP)
    Storage #13x Samsung 512GB NVMe SSD RAID0 (S316NY0HA00959)
    CPU CoolerASUS GX800VHK Water Cooling Dock
    CaseASUS GX800VHK Chassis
    Power SupplyASUS 2x 330W Power Adapter (AC 100~240V, 50/60Hz, 16.9A/19.5V)
    Keyboard ASUS ROG Claymore
    Mouse ASUS ROG Spatha
    Headset ASUS STRIX 7.1 Gaming Headset
    Mouse Pad ASUS ROG Whetstone
    OS Windows 10 Pro x64 / Arch Linux w/KDE Plasma
    Network RouterAsus ROG Rapture GT-AX11000 + GT-AC5300
    Accessory #1 Kensington 4 Port USB 3.0 Hub (K33978WW)
    Dreamonic's Avatar
    Dec 2012
    65
    618
    No. Not in the sense that it's a direct swap over like with a desktop MB and LGA CPU socket.
    Every ROG Notebook model released after the G75 Series use BGA CPU (soldered) packages.
    Every ROG Notebook model released after the G750 Series not only use BGA CPU (soldered) packages, but now also have BGA GPUs as well (no longer have an MXM slot).
    So, unless you have a hot work station on hand or unlimited resources to experiment removing BGA ICs and reballing the replacements, this "user" performance upgrade is literally non-existent with any of the newer ROG Notebook lineup now, or if older models, experimental at best.
Tags for this Thread
