Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: AI suite
    ROG Member Array
    Aug 2014
    6
    AI suite
    Hello
    Why my AI suite will not turn fans off in Smart mode ??? I check the box to auto turn off, but they still work ( it work under fixed rpm mode wich is useless )
    I have watercooling setup, and i would like to have smart mode with curves but to have vents turned off until some point of temperature based on cpu/sensor temp
    ROG Guru: White Belt Array HeroVIII PC Specs
    HeroVIII PC Specs
    MotherboardASUS Maximus VIII Hero - BIOS 3802
    Processori5 6600K, 3,9 GHZ
    Memory (part number)G.Skill Trident Z 3.200 MHz CL16 4x8GB (F4-3200C16D-16GTZ)
    Graphics Card #1Asus STRIX 1070 Ti Advanced
    Sound CardSabre SS9023P SupremeFX 2015
    MonitorSamsung SMART TV 55" 4K
    Storage #1Samsung SM 961 NVMe 256GB OS
    Storage #2Seagate Barracuda 4TB. ASUS HYPER M.2 X4 MINI CARD with Samsung SM 951 NVMe 256GB Game
    CPU CoolerNoctua NH-U12S
    CaseCorsair 450 D, NZXT Sleeved LED Kit White
    Power SupplyCorsair RM850x ( 2018 ), FURUTECH Evolution Power II, with FURUTECH F1 50 R NCF, F1 E 50 R NCF
    Keyboard Rapoo E2000P
    Mouse Rapoo Optical Mouse
    Headset Sennheiser HD 595, Sony MDR 1 AB
    Headset/Speakers Onkyo TX-NR5009, 7.1 B&W 603 s3 Series and ASW 750
    OS Windows 10 Pro 64Bits UEFI 1909
    Network RouterMitrastar
    Accessory #1 ASUS ROG FRONT BASE - FW 48
    Accessory #2 ASUS PCE-AC56, ASUS DRW-24F1MT
    Accessory #3 Microsoft Xbox One Controller + Wireless Adapter for Windows 10
    Dec 2015
    97
    Quote Originally Posted by vex_sb View Post
    Hello
    Try to make the Q Fan in the BIOS; ( In the Advanced Mode, Monitor section and almost down the entire Q Fan ), then the 5 Way Optimization of the Ai Suite excluding the TPU section and in the FAN section enable the Benchmark option, then indicate in which box position you have the fans as you have connected your fans in The different connections: Sistem Fan ..., CPU Fan, CPU OPT, Water Pump etc ..., I hope you understand and help you.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Firstly what kind of fans are you running?
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    hi vex_sb
    as Justin has mentioned which PWM Fan do You use?
    ROG Member Array
    Aug 2014
    6
    Jasmine bambino
    Hi
    I use noctua PWM's
    May 2016
    12
    417
    Hi
    I use noctua PWM's
    Hi vex, do you have other Fans can test for Fan control
    to confirm does it same? or try reinstall AI Suit and update the BIOS to latest version
  7. #7
    ROG Member Array
    Aug 2014
    6
    Quote Originally Posted by FuryA@ASUS View Post
    Hi m8
    Ok, i have other fans ( akasa black shadow i think ) , also pwm.
    I have 3rd fresh win install this week, all time same. THe fans does not stop , the "fan spin up/down" time keeps reseting on every start of PC ( back to 255 second ) and i have checked "auto fan stop " . Maybe i am asking wrong question, should it stop completely if i want ??
    It does stop in RPM fix mode if i put it on 0 , but in smart mode it is running on minimal speed
    Latest ai suite, latest bios, Max viii impact board.
    Also, one other question - how can i get some warning message if temp of my cpu rises above xy temp ???
    Thanks for answer
  8. #8
    ROG Guru: Yellow Belt Array
    Mar 2016
    8
    208
    Hi m8
    Thanks for answer
    Go in to BIOS and change to EZ mode. Look at your fan diagram and change each fan to PWM. . Hit F10 and yes. In Windows open Aisuite and do a fan test. When done assign where your fans are (front-rear- side-back. When done change all your fans to CPU in Source. Remember to save each fan settings!!!!. Go back to the fans you want to Auto-stop and SAVE each time you change something. VERY IMPORTANT!!! Now your fans run like you want. If uou want to change RPM just click on each fan temp setting and drag to the temp you want. =REMEMBER TO SAVE=!!!
  9. #9
    ROG Member Array
    Aug 2014
    6
    Hi
    Tried everything, no result
    The fan on "chassis fan" connector is working fine, turning off depending on temperature, but all fans on extension card are not working as they should, fans are working on min temp instead of turning off
  10. #10
    New ROGer Array
    Mar 2017
    3
    I have the exact opposite problem fans, smart mode refuses to spool up / turn on my fans when the temperature is well above what I set my fans to already be spinning at 100% to be at. What's more, AI suite resets to defaults every time I reboot my computer. Anyone got a suggestion for a program that actually works, since AI suite clearly doesn't. Yes, all fans are working fine - I can get them to spin up with fixed RPM mode, or manually moving the slider in smart mode repeatedly, but it doesn't activate itself when running in the background.
    EDIT: While taking a screenshot and uploading an attachment, GPU temperature went above 80C and overheated. GG Asus - your ****ty software is going to kill my GPU.
