Results 1 to 5 of 5
    New ROGer Array
    Nov 2016
    3
    Question I tried updating my GTX 1070 VBIOS. What did I do wrong?
    I tried updating my VBIOS with the 1.02 updater from ASUS (Released 2016/12/26). During the update process one of my two screens went black and the other showed artifacting, shortly after that I heard a beep coming from my PC. After several beeps my PC restarted on it's own and displayed the screen where Windows says it wasn't properly shut down. After that, Windows booted like usual.
    Specs:
    • GPU: ASUS GTX 1070 Strix OC
    • CPU: i5-3570k @ 4,3 GHz
    • Motherboard: ASUS P8Z77-V LX latest BIOS
    • RAM: Corsair Vengeance 2x4GB DDR3 memory @1600MHz (with X.M.P.)
    • PSU: BeQuiet! Dark Power Pro 11 550W Platinum
    • Operating System & Version: Windows 7 Home 64bit latest updates
    • GPU Drivers: 376.33 clean install without 3D components and Geforce Experience
    • Monitors: Asus ROG Swift PG278Q 1440p@144Hz(primary) + LG E2250 1080p@60Hz
    More miscellaneous info:
    • I have 2 PWM fans plugged into the graphics card
    • ROG Swift monitor was set to 60Hz and is connected via DisplayPort
    • LG montitor is connected via DVI
    • I uninstalled GPU Tweak II prior to the VBIOS update
    • CPU Voltage is usually around 1.288V in Offsetmode
    GPU-Z after reboot: http://gpuz.techpowerup.com/17/01/08/e3m.png
    According to the Micron memory thread the newest VBIOS is 86.04.50.00.63. I guess the update wasn't successful.
    New ROGer Array
    Nov 2016
    3
    I tried updating the VBIOS again with the following differences to the last time I tried it:
    • Unplugged both PWM fans from the graphics card
    • Unplugged the ROG Swift PG278Q monitor
    • Installed the newest version of GPU Tweak II (Set to gaming but was not running during the VBIOS update)
    • Installed the Nvidia driver 376.33 after wiping old drivers with DDU
    • Removed CPU overclock
    This time I counted the beeps from my PC. Shortly after the 10th beep my PC rebooted on it's own with Windows saying it wasn't properly shut down.
    Pic of GPU Tweak II info tab after reboot
    http://i.imgur.com/RIZJXMS.png
    Does nobody know why the update is not successful?
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,859
    Uninstall everything related to the card and use Ccleaner to remove orphaned registry entries.
    Upon reboot enter your BIOS and remove the overclock on your CPU, this is the most likely culprit actually. You should never flash BIOS whether it be the mother board or graphics card or controller firmware etc with anything other than stock clocks.
    New ROGer Array
    Nov 2016
    3
    Icon Road
    Quote Originally Posted by JustinThyme View Post
    I did remove the the CPU overclock as mentioned in my second post. I did so by reverting to optimized defaults in the BIOS (F5 option). If I understood you correctly, I should uninstall GPU Tweak II and the nvidia drivers(with DDU), run CC Cleaner and then try to update the VBIOS?
    ROG Enthusiast Array extreme's Avatar
    Jan 2011
    54
    Vbios update got nothing to do with overclocked cpu. Download and Follow instructions again. File might be corrupted. After flash power down the pc from main?
Tags for this Thread
