Asus GPU Tweak 2 , no startup and fun 0%->100% possible solution
ImSmoke
Hi 2 all,
and sorry 4 my english.
Hardware: Asus GTX 1050Ti OS Strix
Soft: Win10Pro 64bit +GPU Tweak 2 Ver 1.4.0.8 (2016/10/25) +last Driver Nvidia
First problem: 2 fans are not regulated and funspeed is not displayed. Funs worked either stay, or maximum speed.
My solution: I installed the software on a disc 😧 (or "C:\asus\gputweak") and now Tweaker is working properly!
The problem was with no access to the configuration file >>InitData_Card1.ini<<
Second Trouble: No autostart.
My solution:
1. GPUSettings: uncheck "Automatically Start .. " Startup and Monitor. and APPLY !
2. WIN+R, Taskschd.msc, Enter
3. delete Task "GPU Tweak II"
4. make new Task "my GPUTweak", check "...with highes privileges" !
4.1 Triggers "Login" all Users
4.2 Actions: "Start programm" D:\asus\tweak2\GPUTweakII.exe or yours Path
verify after reboot:
1. in Tasksheduler only "my GPUTweak" is
2. in Tweak Settings is no check at "Automatically Start .. "
i hope that will help.
Bahz
Level 12
Locking thread, already similar topic that exists.
Discuss in the thread below:
https://rog.asus.com/forum/showthread.php?89418-GPU-Tweak-won-t-launch-with-windows-when-booting-fro...
