01-13-2017 12:48 PM - last edited on 03-05-2024 10:55 PM by ROGBot
01-13-2017 01:01 PM
01-13-2017 03:42 PM
01-13-2017 04:28 PM
01-14-2017 01:30 AM
FDSage wrote:
Thanks for the response. I was thinking of doing it manually. I'll try inputting the RAM's specifications and see how that goes.
01-14-2017 04:00 AM
Raja@ASUS wrote:
Its the secondary timings of the modules that can be different to what is applied on Auto. Setting Auto or manual for the primaries yields no difference. You can check the XMP profile and apply the full gamut of timings manually. Before you try that, try setting Maximus Tweak mode 1.
-Raja
01-14-2017 01:51 PM
FDSage wrote:
It was set to Maximus Tweak Mode 1 on its own. Before I try anything, do you mean I should leave it on Mode 1, and leave everything on auto, and simply change the DRAM Frequency from Auto to 3200? What of the voltage?
01-14-2017 06:09 AM
01-14-2017 07:07 AM
01-14-2017 07:19 AM
