7700k + Strix z270h 5Ghz overclock - Settings for stability problems
AvengerUK
Hello everyone!
Hoping you can help me with my OC.
Firstly - worth mentioning I have a binned 5Ghz 7700k - which I have de-lidded for temps, and using the latest bios.
I initially thought my OC was stable @ offset voltage resulting in ~ 1.360 (I can't get 1.350, either 1.344 or 1.360 - I know from the bin that 1.350 is the spot).
However, crashed a few times while gaming 😞
I am now back to Manual set to 1.350 - LLC 6. Full settings in screenshots below. Prime95 has been stable @ large 1344 FFT for an hour (more to do) - but realbench (specifically, lux mark) crashes. I think that may be an issue with my drivers as its the display that seems to crash (screen goes off for a moment), so I'm focusing on Prime95. (GPU is stable btw elsewhere).
Temps under stress are max 67-70
Pictures: http://imgur.com/a/Jgw5d
Manual Vcore: 1.35 (Under stress in CPUZ = 1.36)
CPU LLC = 6
CPU Current = 140%
AVX offset: 3
All cores to: 50x
AI Overlcock tuner = Manual
BLK 100
Multicore enhancement = 0
CPU Core/Cache current limit = 255.50
DRAM Volt = 1.35
DRAM speed: 3000
All other CPU volts auto (e.g. SA)
Power limits:
Long: 4095
Package: 127
Short: 3095
DRAM timings are set to manufacturers rec.
Now, if this remains stable - I'm guessing it's good. Note - VCCIO and SA Auto volt quite high though!
But, obviously I want to allow the CPU to downclock / downvolt when idle - however offset doesn't want to be stable at these or higher volts!
Any pointers? (I'm going to guess your going to say "Use Adaptive" - however I've never managed to get that to work! - usually overvolts massively).
Thanks!
8 REPLIES 8
Still tweaking 😉
Now using adaptive @ 1.350 tubo + offset .001 giving 1.360 or in prime95 1.376. (Stability test in progress, with a minus offset of .001 it BSOD)
The problem is, even with LLC lowered, any further voltage gives huge over-volts, e.g. next step would be 1.396 - LLC is currently Level 5.
HWInfo in-case its helpful:
http://imgur.com/a/GwF5i
Thanks,
Chino
Level 15
What I usually do is find my most stable voltage for the overclock that I want. I'd add a few volts just to give it overheard. Then change to Adaptive and call it day.
I believe I've found a stable Adaptive of 1.350, offset + .002 - CPU-Z reports this as 1.376 under Prime95 load, other applications e.g. not stress tests report as 1.360.
Will see how it goes as currently leaving Prime95 to run.
Chino
Level 15
Thanks 🙂
@ 1.320 using LLC of level 4 prime was stable all night.
I'm going to be using it "normally" now to see if it remains stable , fingers crossed.
Well, we've had one crash through a night of gaming.
Could of been worse I guess. BSOD "Page fault in non-paged area"
Not 100% sure what I should do with this, currently I've just put the adpative voltage up .005
(So that's now Vcore 1.325 + offset .001. LLC 4 XMP for memory)
