Results 1 to 9 of 9
    ROG Member Array
    Jan 2017
    5
    ROG G750JM - Problem with GTX 860M -> PC1 Express controller problem?
    Hello everyone,
    I've had my ROG G750JM for about 2 and a half years now and it has never given me any problems until recently. About two weeks ago I noticed that both of my fans behind my screen were really loud and working at what seems to be at full. Additionally, I have not been able to use my GPU (GTX 860M) since that date and basically has made gaming impossible.
    Looking online I tried to fix this problem myself and have done everything among the following:
    • Installed DDU to clean my Nvidia drivers and re-install them again, nothing
    • Re-installed Windows 10. This fixed the fan noise for one re-boot session and then they were loud again.
    • Tried to re-install and remove drivers from device manage, nothing.
    Digging some more I came to realize that my Nvidia GPU wasn't even being recognized any more and that I saw the following error on my PCI controller:
    "This device cannot start. (Code 10)
    An ACPI Power Object failed to transition state"
    If anyone could help me out? I have been trying for almost a month now to fix this! I know my GPU is fine since sometimes when I update my PCI driver it detects it and can even load games for 10-20 minutes before the PCI controller fails. At most, if anyone has any ideas or solutions to make my fans be silent, I'd greatly appreciate that, along with my co-workers (I also use this laptop for work).
    Thank you!
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,188
    What are your temps running Both CPU and GPU?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Jan 2017
    5
    Quote Originally Posted by Clintlgm View Post
    Both hover between 36-42 C.
    ROG Guru: Orange Belt Array Julskey's Avatar
    Feb 2013
    30
    388
    https://rog.asus.com/forum/showthrea...JZ-please-help
    May or may not be applicable to you?
    ROG Member Array
    Jan 2017
    5
    Quote Originally Posted by Julskey View Post
    Thanks for the tip but I don't think I have bricked my GPU because sometimes it is recognized when I turn off my computer but it simply says drivers couldn't start, other times it appears under 3D Video Controller devices and says I need to install new drivers. Most of the time I can't see it and I get a PC1 error as I showed.
    Feb 2013
    30
    388
    Have you overheated your GPU sometime before? If the problem is intermittent (probably intermittent disconnection of GPU), it would likely be a hardware issue considering you already reinstalled windows and drivers.
  7. #7
    ROG Member Array
    Jan 2017
    5
    I don't think so. I was using my computer without any issue or temperature increase and one day it just stopped working. I believe it was preceded by a Windows 10 update.
  8. #8
    ROG Member Array
    Jan 2017
    5
    Anyone else got any suggestions? It seems other people have had similar problems before.
  9. #9
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    I have the same problem.
    Anyone managed to get it fixed?
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
