Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array Veovis PC Specs
    Veovis PC Specs
    Laptop (Model)Eluktronics N131WU
    MotherboardMaximus VI Impact
    ProcessorIntel i7 4770K
    Memory (part number)F3-1866C9-8GXM
    Graphics Card #1Asus strix 1080 A8G
    Graphics Card #2Radeon Navi FE edition
    Sound CardCreative SoundBlaster x7
    MonitorMassdrop VAST
    Storage #1Samsung 850 Evo 1tb
    Storage #22 x Seagate Desktop SSHD ST4000DX001 4TB 64MB Cache
    CPU CoolerCooler Master Sideon 120 XL
    CaseGamerstorm Tristellar
    Power SupplySeasonic PRIME titanium 650
    Keyboard Massdrop ALT keyboard
    Mouse Logitech G602 Mouse
    Headset Sennheiser HD58x Julibee
    Mouse Pad Laser megamat
    Headset/Speakers Creative SoundBlaster x7
    OS Windows 10 pro 64bit
    Network RouterNighthawk 8x
    Accessory #1 Samson GO mic
    Accessory #2 Logitech C9000
    Accessory #3 AVEGANT GLYPH
    Veovis's Avatar
    Jan 2016
    26
    130
    ZenPad 3s 10 issue
    Hello ROG and Asus crowd. I have a new problem with my new Z500M I purchased a few days ago. It has a fun issue of re-allocating memory whenever there's input. This clears and resumes after a normal reset, however to try and figure out the cause I did a factory reset and the problem still occurs. After updates for the installed apps (bloatware) the system file expanded from 1.04 gb to 6.05gb and after idling with a charger for approximately the past two hours has expanded to 33.2 GB, each re-scan with DiskUsage adds another .1GB to the growing System Data file. Is there something I can do to stop this behavior or do I need to contact support?
    ROG Member Array
    Jan 2017
    5
    I think it's best to contact support. it would be safer.
Tags for this Thread
