01-28-2017 08:26 AM - last edited on 03-05-2024 10:21 PM by ROGBot
01-28-2017 06:00 PM
01-29-2017 06:42 AM
JustinThyme wrote:
What I can tell you is this happens for some and not for others. *I can also tell you that GPU tweak is evolving, they are always working on the next release.*
For most simply disabling fast boot in windows remedies this. *For others a work around of opening the settings and unchecking the box to start monitor with GPU Tweak, closing the app, launching it and rechecking the box, then closing the app again and rebooting.*
01-28-2017 06:33 PM
01-29-2017 06:48 AM
Dr_Manhattan wrote:
I have used MSI Afterburner for years without any problems but recently I purchased 2x Asus STRIX GTX1080 and just decided to use GPU tweak II as the software is from the same vendor of the board.
Well, what I found till now is:
Random problems with Windows 10 till I install the v1.4.0.8
Now some problems has fixed but randomly the program doesn't start with windows or start and don't show. (You can see the icon in the tray bar but you can bring the window up)
To solve the problem of GPU Tweak II start but doesn't show the window I changed the configuration to always start and removed the "minimized" option.
Still sometimes doesn't load from startup.
I'm uninstalling GPU Tweak II and will try EVGA PrecisionX OC. If is not stable I will return back to MSI AB
01-30-2017 11:42 PM
01-31-2017 02:19 AM
Nate152 wrote:
Hi guys,
It's an issue with sonic studio 3 and GPU Tweak II, close sonic studio 3 and the GPU Tweak II monitor should open.
The Asus driver team is working on a fix.
You may also notice in GPU tweak II the core clock speed isn't reading correctly with the latest nvidia driver 378.49, they are working on this as well.
01-31-2017 05:36 AM
Nate152 wrote:
Hi guys,
03-02-2017 07:09 AM
05-18-2017 02:38 PM
ikrananka wrote:
GPUTweak v1.4.2.3 with the Honor & Ghost Recon skin has appeared on the ROG STRIX-GTX1070-O8G-GAMING downloads. This at least has solved my problem with not being able to open the monitor.
BUT, the skin is just bloody awful and so distracting. Try reading the text on the Info tab!!!!! Just incredible. There should at least be an option to turn the skin off.
