Hey I would like to configure my system in such manner that a shut down is initiated when the CPU fan speed goes to 0.
Background: Actually I use water pump that generates a fan speed signal on the mainboards CPU fan header (as long as there are no alarms).
I do not find that option - is it possible?
The CPU fan speed is monitored in BIOS and if the pump stops at startup there will be a warning message at POST but I havent figured out how I can force a shutdown in case CPU fan speed goes to zero. Anybody did?
