6 Cards RX 480 8 Gb in system (softaware non working)
Hurtman
Hi all!
I have a 6 cards in my system and not working Asus GPU Tweak II and Aura.
Software installed ok,but non running (not started)
4 REPLIES 4
FuryA
hi Hurtman , which GPU Tweak version have you installed?
Try to uninstall or recovery you OS.
The problem that no version is started and doesn't work if in system more than 4 cards
MSI Afterburner and Trixx (Sapphire) Perfectly work with 6 cards.
If you have an opportunity to report to developers of progrmany providing about a problem, will be very great
All my cards connected through riser PCIe x1-x16.
At one of forums have prompted to me that if in system more than 4 cards, then the program isn't started
Thanks
Thanks
hi Hurtman
Thank You for reporting it
Could You please provide the photo of more than 4 cards and doesn't work if in system 😄
FuryA@ASUS wrote:
hi Hurtman
